Post Batch ZIP Folders Using PHP
I wanted to share this you this small snippet of code which I use to compress my styles before uploading here and submitting on phpbb.com for approval.
Since I have designed several styles over the year, I get a bit annoyed when I need to pack up those styles for a new release... that's where PHP comes to help me.
A quick example could help in understanding:
  • I have several styles in one folder:
    • black_pearl
    • frozen_phoenix
    • mg_autumn
    • mg_xmas
    • milky_way
    • milky_way_red
    • rainbow_pearl
  • I need to create a zip file for each of the above folders in a format like this:
    • black_pearl_1_6_4_20110603.zip
    • frozen_phoenix_1_6_4_20110603.zip
    • mg_autumn_1_6_4_20110603.zip
    • mg_xmas_1_6_4_20110603.zip
    • milky_way_1_6_4_20110603.zip
    • milky_way_red_1_6_4_20110603.zip
    • rainbow_pearl_1_6_4_20110603.zip
  • To do the job I just launch a PHP script
Here are the basic instructions:
  1. To be able to use this script you need pclzip.lib.php library which you will find in Icy Phoenix package or here: PCLZIP
  2. Create a folder where you will put all subfolders to be zipped in different ZIP files, suppose you call this folder backup.
  3. Put in the folder you just created pclzip.lib.php file
  4. Put in the folder you just created all the folders you want to be zipped into separate files
  5. Put this file (make_zip.php) in that folder (highlighted in red you will find the parts you may want to change):
    Code: (make_zip.php) [Download] [Hide] [Select]
    <?php
    * @package Icy Phoenix
    * @version $Id$
    * @license http://opensource.org/licenses/GPL-license.php GNU Public License
    include('pclzip.lib.php');
    @set_time_limit(0);
    //@ignore_user_abort(true);
    @ini_set('memory_limit', '128M');
    $style_version = '_1_6_4';
    $date_suffix = '_' . date('Ymd');
    $source_array = array('black_pearl', 'frozen_phoenix', 'mg_autumn', 'mg_xmas', 'milky_way', 'milky_way_red', 'rainbow_pearl');
    output_header('Creating Styles ZIP Packs');
    $styles_counter = count($source_array);
    for ($i = 0; $i < $styles_counter; $i++)
        $dest_path = $source_array[$i] . '/' . $source_array[$i];
        echo('<hr /><b style="color:#dd2222;">Working on ' . $source_array[$i] . '</b><br />');
        // Kill BAK
        echo('<b style="color:#224488;">Deleting bak files</b>');
        flush();
        $bak_files = array();
        $bak_files = list_files_type($dest_path, 'bak');
        for ($j = 0; $j < count($bak_files); $j++)
            @unlink($bak_files[$j]);
        echo(' ... <b style="color:#228822;">DONE!!!</b><br />');
        flush();
        // Create ZIP package
        $zip_filename = 'phpbb3_' . $source_array[$i] . $style_version . '.zip';
        echo('<b style="color:#224488;">Creating ' . $zip_filename . '</b>');
        flush();
        if (file_exists($zip_filename))
            @unlink($zip_filename);
        $all_files_list = array();
        $all_files_list = list_files($dest_path);
        if (isset($zip))
            unset($zip);
        $zip = new PclZip($zip_filename);
        @chmod($zip_filename, 0777);
        $zip->add($all_files_list, $p_add_dir = '', $p_remove_dir = $source_array[$i]);
        echo(' ... <b style="color:#228822;">DONE!!!</b><br /><hr />');
        flush();
    output_footer();
    exit;
    function output_header($page_title = 'Files List')
        echo('<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">' . "\n");
        echo('<html xmlns="http://www.w3.org/1999/xhtml" dir="ltr" lang="en-gb" xml:lang="en-gb">' . "\n");
        echo('<head><title>' . $page_title . '</title></head>' . "\n");
        echo('<body style="font-family:\'Courier New\', \'Trebuchet MS\', Verdana, Tahoma;font-size:12px;">' . "\n");
        flush();
        return true;
    function output_footer()
        echo('</body>' . "\n" . '</html>');
        flush();
        return true;
    function list_files($source_folder)
        $directory = @opendir($source_folder);
        $files_list = array();
        while (@$file = readdir($directory))
            $full_path_file = $source_folder . '/' . $file;
            if (!in_array($file, array('.', '..')))
                if (is_dir($source_folder . '/' . $file))
                    $files_list = array_merge($files_list, list_files($full_path_file));
                else
                    $files_list[] = str_replace('//', '/', ($full_path_file));
        @closedir($directory);
        sort($files_list);
        return $files_list;
    function list_files_type($source_folder, $extension)
                    $files_list = array_merge($files_list, list_files_type($full_path_file, $extension));
                else
                    $file_details = get_file_details($full_path_file);
                    if ($file_details['ext'] == $extension)
        sort($files_list);
        return $files_list;
    function get_file_details($file_name)
        $file_details = array();
        $file_tmp = str_replace ('http://', '', $file_name);
        $file_path[] = array();
        $file_path = explode('/', $file_tmp);
        $file_details['name_full'] = $file_path[count($file_path) - 1];
        $file_part = explode('.', strtolower($file_details['name_full']));
        $file_details['ext'] = $file_part[count($file_part) - 1];
        $file_details['name'] = substr($file_details['name_full'], 0, strlen($file_details['name_full']) - strlen($file_details['ext']) - 1);
        return $file_details;
  6. You just need to make sure you edit this portion of code including a version number (if you want, otherwise you can leave that empty!) and listing all the folders you want to be zipped... timestamp will be added automatically:
  7. If you did everything correctly, by launching make_zip.php all ZIP files will be created for the listed folders.
  8. Remember to CHMOD 0777 the backup folder (the folder where you put all the folders and make_zip.php).
I hope you will find this snippet and quick tutorial useful.
