Dear all, after upgrading to 15b, i can t create new topics.
I get this error:
Error in posting
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '>Debe especificar un asunto cuando cree un nuevo tema., 0, 1)' at line 1
INSERT INTO phpbb_posts (topic_id, forum_id, poster_id, post_username, post_time, poster_ip, enable_bbcode, enable_html, enable_smilies, enable_sig, enable_autolinks_acronyms) VALUES (9520, 6, 2, 'db116f966a', 1189524775, 'c9d44cc9', 1, 0, 1
Line : 313
File : functions_post.php
Can anybody help me?
Cant Create New Topics
Subject: Re: Cant Create New Topics
R U joking me?
If i don put a subject, this isnt the error.
And yes i ve done it. I solved the issue uninstalling the update... but i would like to know why this happend in order to install it again
regards
novice programmer wrote: [View Post]
R U joking me?
regards
That is really strange... can you provide a test account to test?
I don´t know why, it added the "You´ve to put a subject when a new topic is created" error to the sql query.
nvram wrote: [View Post]
Generation Time: 0.3481s (PHP: 5% SQL: 95%)
