SOLVED - Can't Install Icy Phoenix On Localhost
Subject: SOLVED - Can't Install Icy Phoenix On Localhost
I am trying to Install ICY PHOENIX the last version but I cant do it, it says
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, admin@localhost and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
And in the ERROR LOG says
[Tue Sep 02 19:36:53 2008] [alert] [client 127.0.0.1] c:/program files/easyphp1-8/www/ip/.htaccess: Invalid command 'RewriteEngine', perhaps mis-spelled or defined by a module not included in the server configuration
So I cant install and I remember before the new ICY PHOENIX which came August 22 2008 I mean the last version was normal ayway I hope someone can help me
I am trying to do it over my own pc first
thanks
Inactive User
Subject: Re: I CANT INSTALL ICY PHOENIX
Delete the .htaccess file in the forum root, as it's not meant for what you are using it for.
And in future please denote in the title "Local Host" - and using ALL CAPS in the title is frowned upon here. :(
Subject: Re: Can't Install Icy Phoenix On Localhost
Fixed I love you man!!!
That was the solution!!! I love youuuuuuuuuuuuuu
and when I wanna upload it to my hosting, is it necesary the file I deleted or not?
thanks
vNow why does it says this?
../pafiledb/cache/templates/ca_aphrodite This File/Folder doesn't exist, please upload it and apply the correct CHMOD permissions.
It doesnt exist ??
Inactive User
No ,you don't delete the .htaccess file when you upload to a web-server. It's only non-functional with 127.0.0.1.
And ignore the missing folder as it has no effect on the install; or simply create the folder and put it in the path indicated in the message. ;)
ok thanks
sorry forbeing a little weird but how can I find more templates, I wanna make a template about GAME like WarCraft a simple one , but.. i dont find a good template for it.
so I dont know if u can tell me a website about it or how can I make one?
thanks
Inactive User
I didn't think you were being a little weird, just take some time to explore and get used to the place. ;)
Re Templates:
If you haven't already done so - Check out the downloads link in the Main Menu, or follow the link in my Signature. :P
thnks again, i will try ur website, but if I wanna make my own stile how can I start??
I hope you can help me thanks
Inactive User
That's a big ask, but I'll help where I can. 8)
But please make that a Topic in Templates and Styles. ;)
Subject: Re: SOLVED - Can't Install Icy Phoenix On Localhost
Ok i will post,
Topic out
thanks
Generation Time: 0.1871s (PHP: 9% SQL: 91%)
