Quote With @ And Date And Time
Subject: Quote With @ And Date And Time
Does anybody know how i can modidy this in phpBBXS? All existing mods i found didn't work correctly with XS.
Subject: Re: Quote With @ And Date And Time
WileCoyote wrote: [View Post]
You want to add the date and time to the QUOTE box? Why do you think this is useful? You have a link to the post, which contains date and time... isn't it enough? :roll:
It doesn't matter what i think about it. Some users on our site like this feature from other forums based on ipb or vBulletin. They asked me if we could have this also on our forum. So i decided that i will give them this feature if it is possible.
Ok... but this modifications isn't really a "quick" one... because it requires additional SQL conditions to be added in viewtopic.php: you should add the topic_time together with the post id, and then the time should be converted when viewing the topic. :roll:
At the moment I don't have the time to code this, but if you want to start, than we may try to help you.
Generation Time: 0.1731s (PHP: 10% SQL: 90%)
