Make Main Admin User #1
Article
Reply with quote    Download Post
Post Make Main Admin User #1
The main admin is user # 2 is there any way to make him no # 1 ?? without any problems
cuz in memberlist it shows 1 and in the post, 2
cuz i tried changing with phpmyadmin....but after that....the main admins posts didnt show in the forum at all!?!?!
toledo - View user's profile Send private message
toledo [ Fri 25 May, 2007 14:18 ]
Comments
Post Re: Make Main Admin User #1
Don't change user id's!
Almost all the features are associed with user_id. So if u change it, you'll cause only trouble
Zuker - View user's profile Send private message
Zuker [ Fri 25 May, 2007 14:37 ]
Zuker wrote: [View Post]
Thanks for the advice Zuker. I think when we start fresh (ie 0 posts and users) ...then we can change user ID...but too bad...
toledo [ Fri 25 May, 2007 19:22 ]
There is no user id #1, it starts from 2 and for guest is set to -1
Zuker [ Fri 25 May, 2007 19:32 ]
toledo wrote: [View Post]
Memberlist shows a progressive counter starting from one... that is not the real ID.
In viewtopic you have the real ID.
Forget to change ID to one... you'll have many problems.
Mighty Gorgon - View user's profile Send private message
Mighty Gorgon [ Sat 26 May, 2007 03:36 ]
Thanx mighty!
toledo [ Sat 26 May, 2007 18:51 ]
Thanx mighty!
Why do you want to change it?
tonyf12 - View user's profile Send private message
tonyf12 [ Sun 27 May, 2007 16:03 ]
tonyf12 wrote: [View Post]
[quote user="toledo" post="15068"]The main admin is user # 2 is there any way to make him no # 1 ?? without any problems
cuz i tried changing with phpmyadmin....but after that....the main admins posts didnt show in the forum at all!?!?![/quote]
Thanx mighty!
I mean come on....shouldnt the main admin be No. 1? instead of 2?
toledo [ Sun 27 May, 2007 21:08 ]
There is no #1 So u can't be #1
Zuker [ Sun 27 May, 2007 21:12 ]
He can be number one, but all the codes and mods based on main admin id = 2 won't work fine.
Mighty Gorgon [ Thu 31 May, 2007 18:07 ]
Sometimes ago I raised the same question... is it possibile to have a list of where to find the admin id = 2 related mods in order to changing them?
For example, I am a secondary admin but the previous admin is selling me the domain and the site, I'd like to set myself as main admin... is it a problem to list at least the files involved?
Vortex - View user's profile Send private message
Vortex [ Thu 31 May, 2007 18:31 ]
I haven't a list, you should try to search in all the files.
What is the problem on being admin with a different id? If you have access to FTP and MySQL it's not important the id you have... what is important is just that you have admins privileges.
Mighty Gorgon [ Thu 31 May, 2007 18:40 ]
With SQL access I can reactivate myself or set myself as admin, but another admin can still erase my user... no?
Vortex [ Thu 31 May, 2007 18:48 ]
You can hardcode this including your ID in common.php...
Try to have a look at it.
Mighty Gorgon [ Tue 05 Jun, 2007 02:16 ]
I have an examination on thursday, I'll try just after it
Vortex [ Tue 05 Jun, 2007 10:18 ]
