Post 5 character for search.php needed?
I have never notice that you need 5 characters to get a hit in search.php
If you search for "TEST" you get this:
No posts met your search criteria
But there are a lot of hints Link
Where can I change it to 4 characters? Or the best way is to show a message like
You have to choose more than X characters
EDIT: Hmm, if I search for "MP3" its working: Search for mp3
Post Re: 5 character for search.php needed?
OK, it's solved
"test" is in search_stopwords.txt
That's why the search didn't find it
