Re: SOLVED - User Block Mod
I shouldn't think it would be any problem - But did you check that DWho hasn't already done it and has it available on his site - Before you asked the question?
I also find it annoying that users suggest such things as "I will upgrade to 53 etc, so long as this MOD is available"
You upgrade - Then I'll sure Mike will (if necessary) upgrade the MOD -
WHEN HE FINDS THE TIME!
yeah I did have a look on DWho site, I didnt see it so I posted the question on here..... I would also like to avoid downtime as well, so it only makes sense to upgrade and install the mods at the same time, I have installed the new software on the test area of my server, I now want to add the mods so I know everything works before I go live. I have already installed 2 of your fantastic mods (Security Question and Urls) and all I think is left is the above mod as well as the 80% mod.
I always give praise to you guys as I think you all do a fantastic job, my site has had lots of positive feedback and I owe that to you guys..... so I am sorry if I offended or annoyed you....
