Post Registering Issues
Hi
I've been making tests with the register option several times to test the changes done on the agreement TPL and the further form, and now it says 2 things:
"You've made too much attempts to register. Try later" (or something similar)
or once I'm registered it says
"You've done one register with that IP" (as above, maybe something similar)
What I'd like to know is:
a) How long is that "later"?
b) That only one register per IP can be modified through ACP? Sincerely, in one house could be more than 1 user...
Thanks in advance for your time!
Support Info
Ivory Tower URL: : http://www.torredemarfil.es/foro/ Version: 2.0
SarakinSend private message
Post Re: Registering Issues
Q: How long is that "later"?
A: ACP -> Server -> Login lock time
StructorSend private messageVisit poster's website
Well, if we see that more than a day has passed away, I tried clearing caché and it seems it worked. What it worries me now is the only 1 register per IP issue...
Support Info
no issue
its a feature
ACP >> crackertracker >> settings >> disable the "Register Protection"
New PlayerSend private message
Thanks, new player!
Support Info
