| Comments |
 Re: Wrong Dates On Mini-Calendar Block
Try to check your date/time settings in your profile and in the ACP.
buldo [ Sat 11 Jul, 2009 22:49 ]
I have checked all the settings related to the dates, but everything is in order.
Moreover, as I said, the problem is not the calendar, because in the scheduler the dates are ok, the problem is only in the block portal.
Dann [ Thu 16 Jul, 2009 03:05 ]
I haven't looked at this, but I do note that your main calendar starts the week on Monday and the Mini Calendar starts the week on Sunday. I also haven't looked to see if the start of the week applies to both automatically, or whether they have to be both done manually. Or whether they can be both adjusted at all? :(
If you can't adjust both of them in the ACP to be the same, then I suggest you mark the title as a [BUG]
Correct me if I'm wrong - - But at the moment, I don't know of any country that starts its official week on a Monday?
Inactive User [ Fri 17 Jul, 2009 02:25 ]
Italy, for example! :mrb:
buldo [ Fri 17 Jul, 2009 11:00 ]
Yeah, well ----- :oops:
MG will'a have to'a coda it in Italian and push'a the numbers around'a bit. :mryellow:
Inactive User [ Fri 17 Jul, 2009 13:35 ]
germany, spain etc
other examples that start on monday
spydie [ Fri 17 Jul, 2009 14:15 ]
I've configured everything so that both now begin on Sunday. however, the portal block continues wrong.
Dann [ Fri 17 Jul, 2009 17:17 ]
 Re: [BUG] Wrong Dates On Mini-Calendar Block
Grumble.
If you don´t say it Dann, I would´nt see it.
Got my site running on .27 with calenders block on index and calender in forum, but i did´nt notice the difference.
now i see it . that´s a bug for shure. On my site happens the same problem.
spydie [ Fri 17 Jul, 2009 21:50 ]
I'll check again, but I don't have your problem!
buldo [ Sat 18 Jul, 2009 08:59 ]
Which timezone have you set?
Do you have DST enabled?
Mighty Gorgon [ Sat 18 Jul, 2009 09:22 ]
I don't think that the timezone matters, because in the scheduler appears everything ok but the block is wrong. So I think that the problem is in the block. But really, nothing else matters, I will update my icy phoenix to the latest release. Then, if I find the same problem, I'll post it in the General Support panel of the newest release.
Dann [ Sun 19 Jul, 2009 04:05 ]
How can you be so sure that timezone doesn't matter?
Do you know how GM Times and Dates are generated in Icy Phoenix? Do you know how unix timestamp works?
If I have asked extra details it is because I need to replicate the exact situation of your server to be able to solve it.
If you are not willing to provide the informations requested, I'm not willing to help... :wink:
Mighty Gorgon [ Wed 22 Jul, 2009 13:29 ]
I´ve got DTS enabled.
Timezone is GMT+1
same like yours i suppose
spydie [ Wed 22 Jul, 2009 15:45 ]
