Page 2 of 3
Goto page Previous  1, 2, 3  Next
Post Re: Upload Image Problem
I noticed that go with google chrome but Mozila or explorer does not work
JuveSend private messageVisit poster's website
I will try it..
DanielcSend private messageVisit poster's website
In a new installation, there's no problem. I can upload the images without problem..
I can't test with Google Chrome because it doesn't allow me to log in, even if i delete the cookies...
No body knows? Is there any way to compare the ip_config table between two installations??
Jep download one of them. open it localy and compare to the other one online
But, Isnt there a comparission method? I think it's too big to compare manually... I think that in php there must be something to do this no?
Danielc wrote: [View Post]
You can always dump the tables you want, from all two DB, and then compare them with WinMerge, it's not the "best" solution, but it can work.
~~~ Andrea ~~~
User #379756 on Linux Counter
I did that... I haven't found any strange, just the gzip compression level, that now it is the same as the new installation..
Are there other tables that could produce this error, so i can compare those?
Why not go with mozzila, I installed the latest version, I deleted cookies, what to do with work mozzila
I'm sure that there is a problem with config/icy phoenix... In a new installation, it worked perfect!!..
You can try to export your local "ip_config" table to your live site, obviously make a backup before.
~~~ Andrea ~~~
I tried, but it seems that there is a problem with PHPMyAdmin in my server... It never finishes the backup restore...
Careful
Exporting the local ip_config table brings errors sometimes.
I tried that importing it from my hosting to my localserver, and guess what.
evrything since then went through my localserver.
But, so, what's the problem?? No ideas?
the problem is that in that table is some conection data saved, that has to be changed.
or it could be that when you run your local server, everything is been saved in your hosting-DB.
Post new topic  Reply to topic  Page 2 of 3
