Post KUF
I want to show you a mod, a very useful mod.
Keep unread flags (by author of categories hierarchy).
  1. Keeps the unread flags for a topic active until the topic is read
  2. Activates new post feature for guests
  3. Keeps unread flag when disconnect
Mod desc. wrote:
This mod keeps the unread flags for a topic active until the topic is read.
            It also activates the new post feature for guests.
            The following are new features as a result of the upgrades in May 2005 and 2006:
            1.    Solves the bugs that sometimes gave a user an unread flag on
                his or her own posts, sometimes gave a user an unread flag on other posts that
                he or she had already read and sometimes caused a user to lose all unread flags.
            2.    Keeps unread flags beyond the current page of a topic until
                the user actually visits that page.
            3.     Gives the user a new yellow button on each post (right next
                to the quote button) that allows the user to mark the topic unread
                again from that post onwards (a sort of bookmark function).
            4.    Changes text of unread post link that appears on index page so that
                it reads "View your unread posts" or "You have no unread posts"
                depending on whether or not the user has unread posts.
"This mod keeps the unread flags for a topic active until the topic is read.
            It also activates the new post feature for guests.". But it do this too:
When u disconnect, you don't loose unread message.
Sometimes when I go on a board, I have not alot of time and I couldn't see all new message.
This mod keep unread message as unread.
keep_unread_version_2-0-7.zip
Description: archive of mod. need only .gif and .txt, but .Txt is not allowed
Filename: keep_unread_version_2-0-7.zip
Filesize: 133.7 KB
Downloaded: 145 Time(s)
Post Re: KUF
Does not UPI2DB do this?
DanielcSend private messageVisit poster's website
Post Re: KUF
Seems not, I have try with User Post Information To Database, but when I reconnect with a other computer, I lost all messages.
Post Re: KUF
Informpro,
If you visit your profile here at icyphoenix.com and set your preferences to UPI2DB and not cookies, please post the results when you log on from a different computer.
I've done both, and it's a possible BUG with the latest public version and updates that I have posted in another thread - So please post your findings there in that thread.
Merci!
Post Re: KUF
Seems that it's only working for "new: " (I don't know, there is no new post :p), But no for other (I have see 3times, but when I go on IE it's mark as unread ("U: "))
And "mark all forums as read" don't working =/
I'll W&S for see if it's completly work ^^
Is there any possibility to set at UPI2DB by default ?
Post Re: KUF
there ´s a general switch in configuration IcyPhoenix.
and another switch in unread messages
Post Re: KUF
From what I can see - the UPI2DB global switch in the ACP assumes that UPI2DB is already on?
Problem is it's not! and the switches are out of sequence.
Db > ip_config > ('upi2db_on', '0'),
Change to 1
Then at least it will turn on and off in the ACP.
You still wont get in your preferences the option to turn it on or off because looking at the Db - every user has it "Hard" turned on by default. and no matter what you do you can't change those settings. Doesn't work anyway!
It's also better left for MG to sort this mess out.
Edited by Guest, Sun 27 Sep, 2009 02:09: Struck Out
Post Re: KUF
Lopa!!
Are you aware of the second switch in Configuration-Unread Messages ??
There´s a hole bunch of options for UPI2DB
Post Re: KUF
No mate I wasn't!
But I also don't feel bad about it because it also appears that I'm not the only one..
I went through the ACP twenty times looking for anything that matched UPI2DB - because the db was telling me that there were a whole lot of options somewhere that I couldn't find?
And I've wasted all that time because who the hell is going to associate "Unread Posts" with UPI2DB - when it SHOULD BE NAMED UPI2DB Configuration and then it just MAY be a little easier to find.
Post Re: KUF
Yes, the possibility is in ACP LOL ^^
"ACP > IcyPhoenix > SQL Optimization > [Disable UPI2DB globally
This option lets you disable UPI2DB globally thus saving extra memory.]"
