Re: Upgrading From Phbb2 To Ice Phoenix Not Working Tryed 5 Times To Upgrading :(
Thats means my server is not able to support icy phoenix , what changes in the server will help script run
That is not fully true, as long as a fresh install suceed, but a upgrade don't.
In order to workaround and troubleshoot this thing, this is the way I have tried to update and upgrade his board:
SMF 1.1 -> PhpBB 2.0.22 -> PhpBB 2.0.23 -> Icy Phoenix 1.3.0.53
That last stage do fail, as long as the update suceeds, but quering the server for icy's root index.php redirects to the install procedure (install/install.php). I have been trying to execute the clean_tables_ip.php file, but it returns nothing. All of this happens while the files are chmod 777, so I assume it is not a permissions problem.
It does not mind if I try to update to Icy Phoenix 1.3.0.53 or directly to build 053a RC3.
I think there is something on the files the server os not able to do. On the update page it appears the "Your server does not support file creation and editing", but the cache files of Icy are on their folder and filled with contents...
It is a very rare issue, and I guess you will need to contact your hosting service to fix your server in order to be able to run Icy Phoenix with any issues. I am sorry I cannot help you anymore.
Perhaps you will be aimed to make a SSH login into your server if it is a VPS or a dedicated one ir order to access your server's configuration files.
