Post RSS Language Problem...
Hello again...
My forums native language is Greek.
The problem is that rss feed are displayed such as " ÂãÜëôå ÷ñÞìáôá ìå ëßãá êëéê ôç ìÝñá ! "
The setting at languge files are
$lang['ENCODING'] = 'ISO-8859-7';
//$lang['ENCODING'] = 'UTF-8';
$lang['ENCODING_ALT'] = 'ISO-8859-7';
$lang['DIRECTION'] = 'ltr';
$lang['HEADER_LANG'] = 'en-gb';
$lang['HEADER_XML_LANG'] = 'en-gb';
I also changed the value in ACP>News Configuration>Feed Language > iso-8859-7
Is this a database encoding problem?
How can i fix it?
Thank you !
EDIT...
My todays configuration is
$lang['HEADER_LANG'] = 'el-GR';
$lang['HEADER_XML_LANG'] = 'el-GR';
and in ACP>News Configuration>Feed Language > utf-8
Results: Topic title is shown in greek but content is unundarstandable likeΓ�Γ£Γ�ëôΓ₯ Γ·Γ±Γ�ìÑôÑ Γ¬Γ₯ Γ«Γ�ãÑ ΓͺëéΓͺ ôç Γ¬Γ�Γ±Γ‘ !
Please help me....
borbo - View user's profileSend private message
Thanks for the useful Topic borbo:
Costa (11 March)
Post Re: RSS Language Problem...
Somebody Pleaaaaase?
υπομονή .....
patience ..... LOL
Costa - View user's profileSend private messageView user's personal gallery
Any suggestion guys? Please ??? Why topic title is displayed correctly and topic content is not??
Any ideas?
Sorry, but I can't help with this.
Next version should be full UTF-8 so these kind of issues should be easily to solve.
I have no time to develop a fix for Icy Phoenix 1.3 as it is not easy and it is time consuming.
Thanks for the reply MG....Waiting to update !!
If your DB charset is set to UTF-8, if you set your lang charset to UTF-8 in lang_main_settings, then you can try to do this:
OPEN rss.php
            $topic_title = utf8_encode($topic_title);
            $post_subject = utf8_encode($post_subject);
            $message = utf8_encode($message);
Remove all utf8_encode from there...
I am not sure that it will work fine... but you can try.
