Post Allow Register For An IP That Visual Conf. Blocked
I have pass the attemps to register, but it was 2 days ago. How can I turn the IP on again?
I have checked cTracker and I have no IP's there.
Thanks!
Edit: If I deactivate the Visual Confirmation it works again. But if I turn it back on, it doesn't work .
How can I remove the blocked Ip's? In banned section I have nothing. I clean also cookies and it's the same.
My 2 IP Forums:
tiolalu - View user's profileSend private messageVisit poster's website
Post Re: Allow Register For An IP That Visual Conf. Blocked
I think it is a problem of the counter not being reset in the user table...
Try to check the db...
Can I have a link to your site?
Yep, in the WWW of my profile you have the link . After... 2 weeks I could register again .
I have looked for all DB and I found nothing.
My 2 IP Forums:
