Post Ignore User List
Hi at all!!!
I need an ignore list function on Icy, similar from phpbb3....
I try to find in the forum and the result is this...
http://www.icyphoenix.com/viewtopic.php?f=28&t=3735
Ignore User Mod
The problem... it isn´t adapted from Icy 1.3.0.53a....
Anybody helps me?
PD: Sorry for my bad english... I´m spanish...
Support:
URL: Clan OdC
Template: Prosilver IP blue
Version: Icy Phoenix 1.3.0.53a
Mods: Medal MOD
New Instalation
Hosting: HostGator (US)
jmee84Send private message
Post Re: Ignore User List
Out of interest I had a look at this using the original hack from phpbbhacks and probably have it up to 90% functional for IP *53a.
But!
It appears to conflict with the MOD - FTR (Force To Read) as it uses some variables the same but with different functions, and in particular {$bypass} which with my limited knowledge of IP means that you can only have one or the other.
Dunno, but if any programmer wants the script to where I got up to with all the new vars, constants and the modified install instructions, I'll only be too happy to pass it on.
Lopalong wrote: [View Post]
But!
Thanks for your interest Lopalong!
I have a question:
The conflict is always or only if the forum use FTR MOD?
I'm very interesting in this feature ... maybe someone can help us, or MG, include it in the next IP version
Greetings
Support:
URL: Clan OdC
Mods: Medal MOD
New Instalation
Can you post it here please, Lopa
Gonna have a look on it. Maybe if we change the functions to another name
spydie wrote: [View Post]
Tried all that but it appears to be a global php var and not just a IP var.
jmee84 wrote: [View Post]
Greetings
The vars are both used in viewtopic.php so it makes no difference whether FTR is turned off or not.
Anyway, I'll re-check the install instructions to make sure it reflects what I've changed, as I had to dig out and change many more IP variables as I slowly went along getting it to the point of where it is. Then I'll post it all here either in MODS or Coding Help?
OT:
@spydie - So when are you going to be made a staff member?
OT:
Forget about that man. Don´t want it.
Got enough with my users and sites
Haha!
You wouldn't have to do too much - Just be like the rest of them.
Anyway,
Here's both the original phpBB MOD and the IP one I've been working with.
I didn't add any MG_THIS or MG_THAT constants for the paths etc, until this thing was working.
Best of luck!
Edit:
I suppose that one could by-pass the $bypass var used in "Click here to view post" and simply put a url (whatever/ip/ignore.php) and a small button that replaces the "ignore button, or that message to enable un-ignoring the user with ignore.php.
Edit-2:
Tried the above and it works - so if the worse comes to the worse - it's one way of patching it.
Ignore-Users-IP.zip
Filename: Ignore-Users-IP.zip
Filesize: 7.94 KB
Downloaded: 51 Time(s)
Ignore-Users-phpbb.zip
Filename: Ignore-Users-phpbb.zip
Filesize: 8.25 KB
Downloaded: 39 Time(s)
Thanks Lopa.
Edited my previous post with a possible option - Didn't know you were here.
Sorry, any news?
I'm not sure that works...
Support:
URL: Clan OdC
Mods: Medal MOD
New Instalation
Why you don't go to test it Than you can be sure
Did you test Lopalongs attachment?
y did.
it took me a whiler to find an error in the code.
got it running on my testsite.
if you wanna test. http://pruebas.forofos-f1.com
TheSteffen wrote: [View Post]
Yes, but something wrong ocurred in viewtopic.php... because when the mod is instaled viewtopic does not load correctly (a white page appear...)
Spyde has solved the problem
Thanks Spyde
Support:
URL: Clan OdC
Mods: Medal MOD
New Instalation
spydie, can you please share your solution.
Maybe other users would also like this.
Thanks a lot
in the install instructions off this Mod
$message = $lang['Post_user_ignored'] . ' ' . sprintf($lang['Click_view_ignore'], '<a href="' . append_sid('viewtopic.' . PHP_EXT . '?p=' . " . $postrow[$i]['post_id'] . "&amp;bypass=" . $postrow[$i]['post_id'] . "#" . $postrow[$i]['post_id']) . '">', '</a>');
$message = $lang['Post_user_ignored'] . ' ' . sprintf($lang['Click_view_ignore'], '<a href="' . append_sid('viewtopic.' . PHP_EXT . '?p=' . ' ' . $postrow[$i]['post_id'] . '&amp;bypass=' . $postrow[$i]['post_id'] . '#'  . $postrow[$i]['post_id']) . '">', '</a>' );
theres probably some more errors in that script, but i did´nt stumble over them
