My account of administrator has been blocked, when i try to activate i can´t see the image with the code, it don´t appear, what can i do?
A lot of thanks.
Problem With Ctraker
Subject: Re: Problem With Ctraker
Is GD running properly on your website?
If you are not able to re-activate your account, you can do it via phpMyAdmin using an SQL statement like this (replace table prefix and user_id accordingly):
I resolve this problem using the confirmation without CAPTCHA but:
In registrer when the user don`t write some thinks appears:
How i can do not to appear this errors because the user can register.
A lot of thanks.
[Icy Phoenix Debug] PHP Notice: in file /includes/usercp_register.php on line 559: htmlspecialchars() expects parameter 1 to be string, array given
[Icy Phoenix Debug] PHP Notice: in file /includes/page_header.php on line 1196: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2016)
[Icy Phoenix Debug] PHP Notice: in file /includes/page_header.php on line 1202: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2016)
[Icy Phoenix Debug] PHP Notice: in file /includes/page_header.php on line 1203: Cannot modify header information - headers already sent by (output started at /includes/functions.php:2016)
A lot of thanks.
Did you add some custom fields in the registration form?
Can you please provide a link to check?
I had this error long time ago.
It's related to the check boxes.
you can fix that, killing CrTracker in that file, see here
I read the page that you give me but i don´t understand anything, what i do?
If you cannot solve the issue by following the instructions, then remove the custom field. :LOL:
First step to get helped could be describing us how many custom fields do you have... and how you have called them.
Then we may address you to a fix.
A lot of thanks for the help but I resolve the problem, i don´t remenber that this problems happens to me two or three months ago, look:
http://www.icyphoenix.com/viewtopic.php?f=35&t=4916
Bye and a lot of thanks for the help.
Generation Time: 1.7471s (PHP: 1% SQL: 99%)
SQL queries: 31 - Debug Off - GZIP Enabled
