Post Don't Know What Happened But Icy Phoenix Is Broken :(
Ok so I have no clue what may have happened...but all my chmod's had gotten changed and my host had changed them accordingly (as far as I know)
But now that my site is loading, this is what I'm getting and I can't log into the site.
and also this in another section
any thoughts??  I'm thinking/hoping it's a simple chmod problem I can get into and get going right.
EDIT/UPDATE: Ok....went through and found that the files on the install instruction that are supposed to be chmodded to 777 and this is what I have left.  I can at least log into ICY now
[Icy Phoenix Debug] PHP Notice: in file /blocks/blocks_imp_calendar.php on line 103: fopen(./cache/birthday_-6.dat) [function.fopen]: failed to open stream: Permission denied
[Icy Phoenix Debug] PHP Notice: in file /blocks/blocks_imp_calendar.php on line 104: fwrite(): supplied argument is not a valid stream resource
[Icy Phoenix Debug] PHP Notice: in file /blocks/blocks_imp_calendar.php on line 105: fclose(): supplied argument is not a valid stream resource
Pyro-TechSend private message
Post Re: Don't Know What Happened But Icy Phoenix Is Broken :(
I can confirm that it is a CHMOD issue.
Can you please check again that your folders have the right permissions?
chmod 777 backup
chmod 777 cache
chmod 777 cache/cms
chmod 777 cache/forums
chmod 777 cache/posts
chmod 777 cache/sql
chmod 777 cache/topics
chmod 777 cache/users
chmod 777 ctracker/logfiles/logfile_attempt_counter.txt
chmod 777 ctracker/logfiles/logfile_blocklist.txt
chmod 777 ctracker/logfiles/logfile_debug_mode.txt
chmod 777 ctracker/logfiles/logfile_malformed_logins.txt
chmod 777 ctracker/logfiles/logfile_spammer.txt
chmod 777 ctracker/logfiles/logfile_worms.txt
chmod 777 downloads
chmod 777 files
chmod 777 files/album
chmod 777 files/album/cache
chmod 777 files/album/med_cache
chmod 777 files/album/users
chmod 777 files/album/wm_cache
chmod 777 files/posted_images
chmod 777 files/screenshots
chmod 777 files/thumbs
chmod 777 images/avatars
chmod 777 logs
Thank you for actually answering this.....i appologize that it took me so long to respond.
My website still has the last bit of error in it and yes, all the chmod listings you showed are set to 0777 as far as anything that my host is showing me.
Did you ask to your host if they can set those permissions for you?
I'm quite sure there are some restrictions on your server preventing the script to work correctly.
