Post Setup Returns An Error.!
An error has occurred during installation
An error occurred trying to update the database
The used table type doesn't support FULLTEXT indexes
What does it mean ?
I use EasyPHP 3...
AustinGlenSend private message
Post Re: Icy Phoenix 1.3.0.53a!!!
Are you using EasyPHP right?
Try using XAMPP.
Post Re: Re: Icy Phoenix 1.3.0.53a!!!
One has to wonder whether or not you are asking a question, or judging by your other post - posting the solution to your own problem?
Post Re: Setup Returns An Error.!
Hehehe
I merge this two topics to one.
If I see this post from 2009, it was exact the same
http://www.icyphoenix.com/viewtopic.php?f=2&t=6124
EDIT: Topic marked as solved
