[Fix For Bugs] In Activity Mod
Subject: [Fix For Bugs] In Activity Mod
ahem!
I just installed the Arcade Mod and found a couple of problems before I could get it to work ok. :(
\ip_root\amod\includes\functions_amod_plus.php (1 hits)
Line 1: <?
\ip_root\amod\includes\rewards_api.php (1 hits)
Line 1: <?
Mmmm! It gets worse?
[Icy Phoenix Debug] PHP Notice: in file /amod/includes/functions_amod_plus.php on line 801: number_format() expects parameter 1 to be double, string given
$score_check_1 = number_format($score_check[0]);
It doesn't like the zero? :(
Subject: Re: [BUG] In Activity Mod
Hello,
I get the same error at top of the page (many lines of the same error msg):
Warning: number_format() expects parameter 1 to be double, string given in functions_amod_plus.php on line:
Does anyone have a solution to this issue? :(
I upgraded to PHP 5.3.5 lately, probably that's the problem?
Assuming that you have fixed the <? errors by adding php after the ? like this <?php
In functions_amod_plus.php find this function
function FormatScores($score)
$score_check = explode(".", $score);
$score_check_2 = round($score_check[1], 5);
if ($score_check_2 == '00')
$new_score = $score_check_1;
else
$new_score = $score_check_1 .'.'. $score_check_2;
return $new_score;
and replace the block with the code below.
I don't know if this is going to fix it because I stole it from here and have no way to check or to test it. ;)
http://www.assembla.com/code/icy_ph...lus.php?rev=257
$score_check = explode('.', $score);
$score_check_1 = number_format((double) $score_check[0]);
else
return $new_score;
Hey mort!!
I just wanna tell you this...
that the fix for activity mod works PERFECTLY!!!
much credit to this fix, thanks a lot and have a great day wherever you are ;)
argenta wrote: [View Post]
You're welcome. And I'm in the computer room. LOL! :mricy:
But it would be nicer if MG converted the phpBB3 games arcade because IMHO it has a lot more going for it. ;)
And quite possibly (If you are not aware of this site) http://igames.origon.dk/forum/
the games there seamlessly integrate with the download functions of phpBB3 Games Admin panel.
So yep! it would be nice if Icy Phoenix could be made to access all this phpBB3 stuff in the same way. ;)
mort wrote: [View Post]
Yeah, it would be really nice if someday HE can put his hands over this matter.... :mrgreen:
but for now, lets be happy as things are...... let's not cover him of too much tasks to do!
As for me... its really a relief now without those php error lines!! :)
Subject: Re: [Fix For Bugs] In Activity Mod
Thanks for that! :mri:
I really hope to have some extra free time after the new release, so I can play with other stuff.
Hehehe! I agree :P
Generation Time: 0.542s (PHP: 4% SQL: 96%)
SQL queries: 33 - Debug Off - GZIP Enabled
