Page 1 of 3
oscarxp
 Upgrading To Icy Phoenix
Need instructions of how to upgrade to icy phoenix without loosing anything on my forums.
#1 Tue 09 Jan, 2007 11:25 |
Zuker
 Re: Upgrading To Icy Phoenix
did you try to run update_to_ip ?
#2 Tue 09 Jan, 2007 12:45 |
sonoangelo
when i upload the files it gice me a lot of ctracker's errors, and do the same if i run that file on the main directory
#3 Tue 09 Jan, 2007 13:34 |
andrea75
You HAVE to run it from root... are you logged as admin before run that file?
____________ My Icy forum: www.lineameteo.it
#4 Tue 09 Jan, 2007 14:31 |
sonoangelo
what means, i have to run it from root?  i open my site in the home page, but it give me errors and after i run that file, but give me always the same errors.
Before now i have update the XS 049 to 058b in this way and all right, but now...
#5 Tue 09 Jan, 2007 14:39 |
z3d0
Mighty Gorgon wrote: This beta release is meant for having some flavour of what the Icy Phoenix is going to be, fixing the bugs and maybe obtain some good suggestions to be implemented in the final release... Even if this package is quite stable I would suggest you to install it on live environments only if you are quite good PHP and phpBB.
Might Gorgon wrote: If you are trying to upgrade your existing sites to this release you should consider that the final release may not contain upgrading instructions from this beta. You have been warned...
I suggest you to wait for the first stable relase
#7 Tue 09 Jan, 2007 15:35 |
sonoangelo
U have to be logged as admin and run the update like this http://www.themusicplanet.eu/update_to_ip.php
i'v done this but nothing  tell me some errors, now i reupload the files and you see with your eyes "  "
#8 Tue 09 Jan, 2007 16:18 |
Zuker
Yes, that's because you have upload first the files and you MUST run the update first
run this sql and check
- ALTER TABLE `phpbb_users` ADD `ct_search_time` INT( 11 ) NULL DEFAULT 1 AFTER `user_newpasswd`;
- ALTER TABLE `phpbb_users` ADD `ct_search_count` MEDIUMINT( 8 ) NULL DEFAULT 1 AFTER `ct_search_time`;
- ALTER TABLE `phpbb_users` ADD `ct_last_mail` INT( 11 ) NULL DEFAULT 1 AFTER `ct_search_count`;
- ALTER TABLE `phpbb_users` ADD `ct_last_post` INT( 11 ) NULL DEFAULT 1 AFTER `ct_last_mail`;
- ALTER TABLE `phpbb_users` ADD `ct_post_counter` MEDIUMINT( 8 ) NULL DEFAULT 1 AFTER `ct_last_post`;
- ALTER TABLE `phpbb_users` ADD `ct_last_pw_reset` INT( 11 ) NULL DEFAULT 1 AFTER `ct_post_counter`;
- ALTER TABLE `phpbb_users` ADD `ct_enable_ip_warn` TINYINT( 1 ) NULL DEFAULT 1 AFTER `ct_last_pw_reset`;
- ALTER TABLE `phpbb_users` ADD `ct_last_used_ip` VARCHAR( 16 ) NULL DEFAULT '0.0.0.0' AFTER `ct_enable_ip_warn`;
- ALTER TABLE `phpbb_users` ADD `ct_last_ip` VARCHAR( 16 ) NULL DEFAULT '0.0.0.0' AFTER `ct_last_used_ip`;
- ALTER TABLE `phpbb_users` ADD `ct_login_count` MEDIUMINT( 8 ) NULL DEFAULT 1 AFTER `ct_last_used_ip`;
- ALTER TABLE `phpbb_users` ADD `ct_login_vconfirm` TINYINT( 1 ) NULL DEFAULT 0 AFTER `ct_login_count`;
- ALTER TABLE `phpbb_users` ADD `ct_last_pw_change` INT( 11 ) NULL DEFAULT 1 AFTER `ct_login_vconfirm`;
- ALTER TABLE `phpbb_users` ADD `ct_global_msg_read` TINYINT( 1 ) NULL DEFAULT 0 AFTER `ct_last_pw_change`;
- ALTER TABLE `phpbb_users` ADD `ct_miserable_user` TINYINT( 1 ) NULL DEFAULT 0 AFTER `ct_global_msg_read`;
- CREATE TABLE `phpbb_ctracker_config` (
- `ct_config_name` varchar(255) NOT NULL,
- `ct_config_value` varchar(255) NOT NULL,
- PRIMARY KEY (`ct_config_name`)
- CREATE TABLE `phpbb_ctracker_filechk` (
- `filepath` text,
- `hash` varchar(32) default NULL
- CREATE TABLE `phpbb_ctracker_filescanner` (
- `id` smallint(5) NOT NULL,
- `filepath` text,
- `safety` smallint(1) NOT NULL default '0',
- PRIMARY KEY (`id`)
- CREATE TABLE `phpbb_ctracker_ipblocker` (
- `id` mediumint(8) unsigned NOT NULL,
- `ct_blocker_value` varchar(250) default NULL,
- CREATE TABLE `phpbb_ctracker_loginhistory` (
- `ct_user_id` int(10) default NULL,
- `ct_login_ip` varchar(16) default NULL,
- `ct_login_time` int(11) NOT NULL default '0'
#10 Tue 09 Jan, 2007 16:36 |
sonoangelo
oh damn  reupload the old or run this sql query? xcuse me for the time tha you lose for me
#11 Tue 09 Jan, 2007 16:40 |
Zuker
run that sql and try to run update first
#12 Tue 09 Jan, 2007 16:44 |
sonoangelo
now tell me this error  the update went right , but now i have a block problem
#13 Tue 09 Jan, 2007 16:51 |
Zuker
what problem?
#14 Tue 09 Jan, 2007 16:52 |
sonoangelo
look now
Template->make_filename(): Error - template file not found: portal_page_headerleft.tpl
i HAVE that file
#15 Tue 09 Jan, 2007 17:01 |
Page 1 of 3
