Post [SOLVED] One Point More In The Info
I have one point more in the info zone.
How I can remove that point?
 point
DimoSend private message
Post Re: One Point More In The Info
You should check in CMS what that link is for... maybe is a feature not enabled.
If you can report here, I will check.
Thanks Boss for answer quickly
In my CMS we can see that:
info
Then...? Where is the problem?
Could you check if this line is present in your lang_main.php Dimo?
    'LINK_REFERERS' => 'HTTP Referers',
Maybe it is missing in the spanish translation?
i might have overseen it, when i did the pack
In the Spanish version is not found.
And in the English version I deleted the line but remains the error.
Why did you delete the line in the English Language. ?
If you put it back and set your site to "English" and the problem disappears - then as Spydie suggested he MAY have missed the line in the Spanish Translation.
You don't help by deleting things and then stating that it's still not working?
And if you provide a link to your site - someone may be able to look into the script/html to see what is happening there?
mort wrote: [View Post]
Mort if you want see the script/html... my site is www.ykz.laforo.org
Thanks Guapo
@ Dimo
OPEN language/lang_spanish/lang_main.php file
FIND:
  1.     'LINK_REFERRERS' => 'Referidos HTTP',
REPLACE WITH:
  1.     'LINK_REFERERS' => 'Referidos HTTP',
ThE KuKa wrote: [View Post]
@ Dimo
FIND:
REPLACE WITH:
When I make what you say my site fall.
If I erase the file "language/lang_spanish/lang_main.php" the site come back well but in english.
I make one user for you...
User: administrador
Pass: 123456789
Yes I see that the English language is working ok so try uploading this file to your Spanish Language folder making sure you upload it in BINARY format.
ThE KuKa's fix has already been applied to it.
If that doesn't fix it, then something is either missing or not commented out, and for that, one of the Spanish guys will have to sort out.
lang_main-spanish.zip
Filename: lang_main-spanish.zip
Filesize: 39.48 KB
Downloaded: 101 Time(s)
that should have fixed it Mort.
i had no time to review the latest changes. gonna do that in the next days
Post Re: [SOLVED] One Point More In The Info
mort, the problem is solved ^^
Dimo wrote: [View Post]
I'm not saying that you did and I'm also not aware of your expertise, but IF you have uploaded any files in ASCII format then I suggest that you re-upload them all using BINARY format.
Because this line below becomes a real problem with ASCII
'No_post_mode' => 'No post mode specified', // If posting.php is called without a mode (newtopic/reply/delete/etc, shouldn't be shown normally)
If ASCII folds this line to something like this.
 Then the shouldn't would need to be shouldn\'t
And that's how easy it is to create problems and also "Kill" a script.
That line would break PHP anyway, since it's not a comment if folded
