Post New Blank Page
Hi!
How can I make a blank page without using .tpl files?
with the previous release, I used: includes/page_header.php and includes/page_tail.php
Gianni PBSend private messageVisit poster's website
Post Re: New Blank Page
Not exactly sure what you are trying to do
But the file name would have to be a php file - myFile.php etc. Then you would have to echo the mark-up something like this.
<?php
echo '<table width="100%" cellpadding="0" cellspacing="0" border="0">
            <td class="bgextra">
            <div align="center">
                        <a href="blah/index.php?">Some tag or image</a>
            </td>
            </table>
If you have other apostrophes in whatever you add then you would need to comment them out like so.
<?php
echo '<table width=\'100%\' cellpadding=\'0\' cellspacing=\'0\' border=\'0\'>
            <td class=\'bgextra\'>
            <div align=\'center\'>
                        <a href=\'blah/index.php?\'>Some tag or image</a>
            </td>
            </table>
As I said - Not exactly sure what you are trying to do?
now it's 2 functions :
  1. function page_header($title = '', $parse_template = false)
  1. function page_footer($exit = true, $template_to_parse = 'body', $parse_template = false)
Informpro wrote: [View Post]
How can I call them?
here it's my previous request: http://www.icyphoenix.com/viewtopic.php?t=3227
I don't think having 500 pages is a good idea anyway ... What are they "about" ?
today there are 5.500 pages
I don't know how I can call these 2 functions in my blank page.
I tried to use:
page_header($title = '', $parse_template = false);
but it doesn't work
I don't know why you have so many pages... but you can achieve the same result in several ways.
Try to check this tutorial: CUSTOMIZATION - Create A Custom Page In Icy Phoenix 2.0
Post Re: [SOLVED] New Blank Page
thank you MG
It works, but now I have a little problem with special characters, look at: www.salsapuglia.com/discografie/ale...juangabriel.php
Filesize: 77.29 KB
Viewed: 98 Time(s)
Save your page with encoding: UTF8 (without BOM).
thanks...solved
