Post Can't Download Music Files
for some reason when i go to download a music file (mp3) it gives me a error.
  1. Critical Error!
  2. message_die() was called multiple times.
  3. Error #1
  4. The selected File no longer exists
  5.
  6. 404 File Not Found: The File 15 Miracles .mp3 does not exist.
  7.
  8.   Error #2
  9. SQL ERROR [ mysql4 ]
  10.
  11. [0]
  12.
  13. BACKTRACE
  14.
  15. FILE: includes/functions.php
  16. LINE: 6070
  17. CALL: sql_db->sql_error()
  18.
  19. FILE: includes/pafiledb/modules/pa_download.php
  20. LINE: 248
  21. CALL: message_die()
  22.
  23. FILE: dload.php
  24. LINE: 62
  25. CALL: pafiledb_download->main()
  26.
  27.
  28.
  29. Line : 909
  30. File : /includes/db/mysql.php
  31.   Please, contact the webmaster. Thank you.
  32.
how do i fix this error?
if i enter a url it works.
Edited by juggalo_master, Sun 16 Sep, 2012 07:59: added if i enter a url to the music file it works
juggalo_masterSend private message
Post Re: Can't Download Music Files
Maybe because your file is not named properly... try to remove all spaces and strange chars before uploading... those are not good for internet addresses.
i never thought of that LOL. i will try that. forgot some codings can't handle spaces in files.
thanks that was the problem.
i also have a question: how would i go about getting the .php not to show up at the end? i got the htaccess to show but i want to know how to change the url variables to reflect the change.
Could you please make a new topic for all of your "other" questions as it does help others looking for similar fixes or problems etc.
And it also gives others more of a chance to participate.
