Hi There
I've been using Icy Phoenix for the past three years without any problem until now when I try to search for a user in the admin area (MANAGE). The error is: Error 324 (net::ERR_EMPTY_RESPONSE)
Version of Icy Phoenix: 1.3.0.53b
http://theracersshop-pr.com
I hope you can help
Subject: Re: Error 324 (net::ERR_EMPTY_RESPONSE)
Very strange. Could you try disabling gzip compression? Sometimes I get an error like yours because I have it ON and an error pops up, breaking everything.
Else, can you tell us when that happens ? Searching for an existing users ? A non-existent one ?
This error appears when trying search an existing user and Gzip compression is off.
Well, I certainly don't have such comportement.
Can you reproduce it everytime ? Does it happen with every user or a single one ? Do you have any PHP / apache logs?
Very strange... if you enable GZIP the error disappear?
May I ask why you didn't upgrade to IP 2.0 so far?
Can you reproduce it everytime ? yes
Does it happen with every user or a single one ? Happen with any member
Do you have any PHP / apache logs? Yes got it. Do you want to see it?
Informpro wrote: [View Post]
You can access the log file in http://theracersshop-pr.com/portal/error/
Did you read my post?
Sorry Mighty Gorgon, I try to answer your message, but came a message that says:
"You are the last poster in this topic: you cannot write new posts within 24 hours from your last post unless someone else answers in the meantime."
When you have that error... just edit your own post, I think you can do that.
First answer Informpro message and then try to respond to your message and left that comment or error.
Generation Time: 1.7243s (PHP: 1% SQL: 99%)
SQL queries: 31 - Debug Off - GZIP Enabled
