Sarakin
 Captcha Images Went Blank
It seems we had some kind of problem with captcha images during our proccess of updating to Icy 2.0. They aren't displayed, so right now nobody can register or activate their user if they fail to login. Can anybody throw a light here, please?
____________ Support Info
Ivory Tower URL: : http://www.torredemarfil.es/foro/ Version: 2.0
#1 Tue 25 Aug, 2015 13:47 |
Informpro
 Re: Captcha Images Went Blank
I think there was some special instruction... Some folder you had to move for images.
Which version did you update from?
EDIT: it's actually in the readme:
Quote: Rename the following folder:
files/posted_images ==> files/images
did you do that?
#2 Wed 26 Aug, 2015 21:28 |
Sarakin
Yes, but that folder is empty
#3 Thu 27 Aug, 2015 13:58 |
Informpro
That's weird. Can you show me a picture of your captcha configuration?
#4 Fri 28 Aug, 2015 10:39 |
Sarakin
The weirdest thing is that it seems to work on a local instalation  Could it be some trouble caused by permissions over that folder or something like that? By the way, here's the pic:
#5 Fri 28 Aug, 2015 16:27 |
Informpro
That could be, or the server could be.. weirdly configured... But then, why did it work before? I'm not sure.
It'll be even harder to track down if it's not reproducible on your local installation :(/
#6 Fri 28 Aug, 2015 21:05 |
Sarakin
The point is that we moved to another server too, that's why we suspect it could be permissions related, and why I asked if that folder should have some temporal pic inside (or whatever) inside.
#7 Sat 29 Aug, 2015 13:12 |
Informpro
Oh, sorry, I missed that part. Then yes, that could be very well related to chmod. Have you checked those? The list should be in the README file, again.
It could also be that gd isn't installed / is weirdly configured, but you'll have to ask your host to know for sure!
#8 Sun 30 Aug, 2015 00:45 |
Sarakin
Nope, CHMOD permissions are OK. Any other way to check why Captcha is not working?
#9 Mon 31 Aug, 2015 18:37 |
Informpro
If your new server has some kind of error logs, then it'd be very helpful to get them
#10 Mon 31 Aug, 2015 23:02 |
AlvinPP
Informpro wrote: [View Post] Oh, sorry, I missed that part. Then yes, that could be very well related to chmod taxi aeroport . Have you checked those? The list should be in the README file, again.
I had the same situation, your solution help me
#11 Fri 04 Dec, 2015 19:42 |
