SOLVED Are There Any CSS Index?
Subject: Are There Any CSS Index?
I'm working on the Theme and the CSS in order to try to identify what can be change. I'm using the FFox Firebug, but I'm not able to find some things and I'd like to know if there's a finer tool or a CSS index where all parts might be listed.
Subject: Re: Are There Any CSS Index?
Things are changing so much with themes and .css, I would put theming on hold until the next release. ;)
But in answer in to your question - There is no CSS index - - - Yet! :)
common.css and style_*.css are the two main considerations, but that's going to change also. :(
Do you mean that I'll have to change on the future anything I change now to set my Style? I'd put it on hold depending on how long it lasts the next release... and I guess it will long months, so I think I'll keep working on my new style and I'll change whatever I had to when the next release comes.
It's a real pity. Anyway, I've just reviewed lightly the CSS and I guess I have checked now almost all I need. One of the things I missed to find is the background of the cell of the forums new messages led, so I leave the pic:
Is possible to set a special background for that zone through the CSS or the TPL files?
Lopalong wrote: [View Post]
View source will show you what class is used there, it may also be a template class-VAR when you look into the tpl file :( - Either way it's in index_box.tpl
:mricy:
:mricy:
And what I'm supposed to do once I know the "class"? I'm not a expert on templates :? :P
The class denotes what markup is used by the .css in much the same way that url's have anchors. If you can't find a suitable class to change it to, then you may have to add a "Special Class with a new name / anchor to the .css" - And that's basic html and .css
you can try this
open your template index_box.tpl
find
replace with
i added name "rowl" you can chose diferent name but must be same in css
open your template style.css
affter last line add this
where #00DEEA is color you want to change
and you shoud get something like this
PS. backup your index_box.tpl and style.css before you try this , just for security :wink:
find
replace with
Generation Time: 0.8849s (PHP: 2% SQL: 98%)
