Post [DEPRECATED] Re-Release And New Releases Of All Icy Themes Styles.
These styles are deprecated and no longer supported - Please upgrade your Icy Phoenix to version 1.3.*
Thanks for the useful Topic Lopalong:
Mighty Gorgon (18 May), awill (19 May)
Post Re: Pre-Release For Beta Testing - 4 Themes.
hey lopalong,
thanks for your nice work... the new themes looks great...
keep up your good work...
Play Games at GamesCampus!
Thanks KugeLSichA,
I think I'm up to about version 10 on all of the themes I've done - So many templates - So much tweaking.
thanks ....
great tempz
i finaly found time to try it
Limun - View user's profileSend private messageView user's personal gallery
Wow, great work Lopalong. Mostly I like Crystal-Gold.
Thanks for your time and the great tempz
Great, great!
You know which one I like!!
Well, if I can figure out how to log back into my forum, I would like to try a couple of your nice themes!!!
My main IP 1.3 site
My IP 1.3 styles test site
gearhead - View user's profileSend private messageVisit poster's websiteView user's personal gallery
OH! Brother,
I've been away for a few days and everyone wants me!
@ TheSteffen
Thanks,
Even "Cloning" some of iThemes stuff is / was a lot of fiddling with .css and graphics to make them compliant with IP Themes.
Don't know if there's much of the original stuff left aside from a few headers, gradients and shadows.
@ Gearhead -> "Locked Out" ?? Just going to check your PM.
Crystal Hop hog? You might have to do some 'splainin on that one.
I like it, but maybe it's a 'down under' thang? I mean, I live in a small town, but the last guy that did that, they put him UNDER the jailhouse!!!! He he.
My main IP 1.3 site
Hop Hog - The classic English Pub!
That's cool!
Well, we have a couple of those, but I was thinking a hop-hog was a guy who can't seem to get out from under the tap!!
My main IP 1.3 site
Post Re: Re-Release And New Releases Of All Icy Themes Styles.
These themes and all other Icy Themes Styles have been released or re-released after being modified. The first post has been changed to include the details.
Thank you very much for these really nice themes.
I've just integrated some new classes in mg_themes so you will be able to easily adapt each of these template without having to rewrite tpl files.
As soon as I have completed some refinements I will share.
Hi Luca,
You're welcome to the themes, but I think I'll leave them all at Icy Themes for the time being as updating and answering questions all over the place tends to wear me down a little. I think you understand what I mean.
Are you doing anything to address the "Small Blocks" and the cms blocks as in the picture. ?
These are the Modded .tpl for the general style: (There may be others - I'm still working on it!)
nav_quick_links.tpl
links_leftblock.tpl
profile_cpl_menu_inc_start.tpl
profile_friends_body.tpl
New Vars would be nice for those.
CMS Blocks ? I've simply dropped the header and border and hard-scripted the small block files to include the new style. But I know there is a better way, and only you can make them permanent alterations to the CMS.  And that would be difficult, as it would only need to affect the "Small" blocks.
At the same time it's also not too difficult for an IP webmaster to drop the small headers and borders in the CMS and use the alternative block.tpl's
Edit: As it is at the moment with the CMS and the way I have done it, I don't see any problem adapting any other styles by adding 6 "re-named" copies of existing graphics, and adding the extra .css. But I haven't tested it yet either!
There is an easy way to tho that without changing any PHP file.
You need just to fill some new vars in CFG like these for example:
        $images['tbl_b_l'] = '';
        $images['tbl_b_c'] = '';
        $images['tbl_b_r'] = '';
And then recall them in template using {IMG_TBL}.
If you need more, just create them in CFG and add them to the bottom in this section:
    'IMG_TBL' => $images['tbl_b_l'],
    'IMG_TBC' => $images['tbl_b_c'],
    'IMG_TBR' => $images['tbl_b_r'],
You will then be able to use them in your template.
P.S.: you want me to remove your themes from the Download section in this site?
Thanks MG, I wasn't sure if cms???.php would recognise the {IMG_VAR} and would create the same problem as pafiledb.php did.
So I used T_IMAGESET_PATH as a test. But I will change them where possible to a new IMG_VAR.
Yes you can remove the styles from your DB - But I would like you to have a copy of all of the theme.zip files and screen shots stored somewhere on your own PC or server.
