Post Changing The Icy Portal Link To Another External Portal
The situation is that we have our Portal located on another site and, logically, under another Soft, but first of all I guess I should post a pic in order to show what I mean:
user_19429_plantillas_portal
About the Header (1), I guess I'll have no problems, because replacing the code inside the overall_header.tpl and typing the code of the link which I desire should be enough, but I get lost with the "Locater" (2) which shows the forum place (or the portal one, but that's not my case) you are in. That's because I don't know which variable I have to modify and what part to replace in order to include the link I want.
Greets and thank you very much in advance.
Sarakin - View user's profileSend private message
Post Re: Changing The Icy Portal Link To Another External Portal
includes/constants.php
define('PORTAL_MG', 'index.' . $phpEx);
