Post Spanish Buttons
****Deleted*****
Never mind, problem solved.
EDIT:
And then again the same problem. I installed Black Pearl theme and the Spanish buttons are not working. I checked the english_language and they have .png extension while spanish_language have .gif extension.
Do I have to rename the buttons in order to get them working?
Thanks for your kind help.
Regards,
BIG BOSS
BIG BOSS - View user's profileSend private message
Post Re: Spanish Buttons
Maybe it's my fault... I'll check those buttons as soon as I have some free time.
Please use English ones in the meantime, or convert them to GIF using Photoshop if you have some free time for doing that.
Thanks MG, I can just rename to the new extension and they work. I'll try to find the time to do it. All variations of Pearl style have the same problem.
Take care!
Regards,
BIG BOSS
