Post Forum Layout
Hello guys
I wonder if anyone can help? i would like to make my forum so its all in one box but im not sure how?
tia
TECHNIQUE - View user's profileSend private message
Post Re: Forum Layout
Can you try to create an image explaining what you need please?
forum
Rather than them all being seperate i would like them all in one box. So general would be the top then all others under it but not as sub forums. i did it a long time ago but cant for the life of me remember how
Hope this makes sense
tia
Technique
You are using phpBB 3 right? I'll move this request to the appropriate support forum.
As soon as we find some free time, me or someone else will try to help you.
No im using icy phoenix with black pearl template
Sorry for the tennis match with your question as the ball.. i ve moved you back to icy
Oh damn... then I'm the one who has to answer this...
Try this.
OPEN templates/default/index_box.tpl
<!-- BEGIN catrow -->
<!-- BEGIN tablehead -->
<div id="{catrow.MAIN_CAT_ID}_f_h" style="display:none;">
{IMG_THL}{IMG_THC}<img class="max-min-right" style="{SHOW_HIDE_PADDING}" src="{IMG_MAXIMISE}" onclick="ShowHide('{catrow.MAIN_CAT_ID}_f','{catrow.MAIN_CAT_ID}_f_h','{catrow.MAIN_CAT_ID}_f');" alt="{L_SHOW}" /><span class="forumlink">{catrow.tablehead.L_FORUM}</span>{IMG_THR_ALT}<table class="forumlinenb" width="100%" cellspacing="0" cellpadding="0">
<tr><td> </td></tr>
</table>{IMG_TFL}{IMG_TFC}{IMG_TFR}
<div id="{catrow.MAIN_CAT_ID}_f">
tmp = '{catrow.MAIN_CAT_ID}_f';
if(GetCookie(tmp) == '2')
    ShowHide('{catrow.MAIN_CAT_ID}_f', '{catrow.MAIN_CAT_ID}_f_h', '{catrow.MAIN_CAT_ID}_f');
</script>
{IMG_THL_ALT}{IMG_THC}<img class="max-min-right" style="{SHOW_HIDE_PADDING}" src="{IMG_MINIMISE}" onclick="ShowHide('{catrow.MAIN_CAT_ID}_f','{catrow.MAIN_CAT_ID}_f_h','{catrow.MAIN_CAT_ID}_f');" alt="{L_HIDE}" /><span class="forumlink">{catrow.tablehead.L_FORUM}</span>{IMG_THR}<table class="forumlinenb" width="100%" cellspacing="0" cellpadding="0">
<!-- BEGIN cathead -->
    <!-- BEGIN inc -->
    <td width="46" class="{catrow.cathead.inc.INC_CLASS}"><img src="{SPACER}" width="46" height="0" /></td>
    <!-- END inc -->
    <td class="{catrow.cathead.CLASS_CAT}" width="100%" colspan="{catrow.cathead.INC_SPAN}"><span class="cattitle"><a href="{catrow.cathead.U_VIEWCAT}" class="cattitle" title="{catrow.cathead.CAT_DESC}">{catrow.cathead.CAT_TITLE}</a></span></td>
    <td class="{catrow.cathead.CLASS_ROWPIC}" colspan="3" align="right"> </td>
<!-- END cathead -->
    <th colspan="{catrow.tablehead.INC_SPAN}" nowrap="nowrap"> {L_FORUM} </th>
    <th width="50">&nbsp;{L_TOPICS}&nbsp;</th>
    <th width="50">&nbsp;{L_POSTS}&nbsp;</th>
    <th width="120" colspan="2"> {L_TOPICS} / {L_POSTS} </th>
    <th width="180"> {L_LASTPOST} </th>
<!-- END tablehead -->
{IMG_THL}{IMG_THC}<span class="forumlink">{L_FORUM}</span>{IMG_THR_ALT}<table class="forumlinenb" width="100%" cellspacing="0" cellpadding="0">
<tr><td> </td></tr>
    <th nowrap="nowrap"> {L_FORUM} </th>
<!-- BEGIN tablefoot -->
<!-- END tablefoot -->
<!-- END catrow -->
<!-- END catrow -->
forum_2
Thats what i got after code change. Should have said this before but i would like it how it is on this site with icy phoenix support as forum heading the  under it patches and so on. hope that helps. Im sure the last time i used icy i just had a button in the ACP but it was a while ago so maybe im wrong.
Thanks for all your help so far
you still have
ACP-Configuration-Icy_Phoenix-Forum
forum compression
play with the settings,
Icy-Mods.com ( IP 2.0 RC-1)
Sorry for being stupid but i dont follow, i went to ACP-Icy Phoenix-forum but only have 6 settings nothing to do with compression?
first one is forum compression
forum_3
Thats what i see and i have put a tick in each setting but still no joy is this the page you talked about?
Index Packing. set that to medium or none
and play with the other settings aswell, till the time you get more or less what you want
Forgive my ignorance but is there a link to instructions that explains this process from the begining?
boobaloo - View user's profileSend private message
