Post [Solved] Template "Post-it" Incomplete....
Hi
I don't know if the template "post-it" (that I like a lot...) is still developed, if not, sorry for having asked.
Anyway, it's incomplete, the top bar isn't working (icons for "home" etc. not showing off etc.)
If it's not the right forum, please move it, I didn't know if ask here or in the template forum...
P.S.
These are some error logs
File does not exist: postit/style_css.php
File does not exist: common/common_colors.css
File does not exist: common/dock.css
Posetteforever ...3D Art for fun...
tormentorSend private messageVisit poster's website
Post Re: Template "Post-it" Incomplete....
tormentor wrote:
is still developed,
as Luke said, is not ready yet
CostaSend private message
Uh... I'm pretty sure to have downloaded it from a regular section... Nevermind...
tormentor wrote: [View Post]
Yes, you did:
http://www.icyphoenix.com/styles.php?s=40
I will move you post to "templates".
Are you using IP 1.3?
If you have no modifacations in your postit style, can you try a new install with the one I posted above?
The file is called: postit/style_postit.css
and it is inside
So, anythink should be wrong. Because you wrote it is looking for "postit/style_css.php"
tormentor wrote:
from a regular section... ..
Sorry tormentor, I was wrong. I thought it was related Designing Lightning Phoenix.
Ι confuse the Post-it with Lightning Phoenix.
TheSteffen wrote: [View Post]
and it is inside
Never mind buddy, it was my fault   I overwritten an old version of the style while tere were extra files in the subdirectory and they had to be removed, this topic can be closed...
No, I'm "almost" on 1.3 but it's more a patched version of the beta that I installed... At this point it can't be upgraded so easily...
Post Re: [Solved] Template "Post-it" Incomplete....
No problem, greate you solved it
Post it template seems ok
yaruigonSend private message
