Post Header With Html
That such icy phoenix
I need a help with the header...
I created a picture to explain my idea...
create a header with html, To add buttons like this in the picture:
Example:
dmpep
Madara - View user's profileSend private message
Post Re: Header With Html
and why don´t you just include icy´s search function in your overall_header file ??
Icy-Mods.com ( IP 2.0 RC-1)
spydie wrote: [View Post]
but can add the search in the header "logo" in overall_header?
You should create a global block in CMS in header top right position.
Have a try and let us know.
well I did what you said but the navigation buttons look bad
irbnq
kg8we
This is the code I'm using
By the way could help me with the code to put a button on the logo
Thanks!
hm .
looks like your using the tabs mod from TopoMotoV3x
you should center the text and maybe use bold text
These are pictures not links, do not fix to center the text and put bold text.
here > http://www.icyphoenix.com/viewtopic.php?f=40&t=7615&start=0
I think that is the html I'm using that makes the buttons from being bad
Code:
<table width="960" height="210" border="0" align="center" cellpadding="0" cellspacing="0" background="/templates/icy_phoenix/images/dark/sitelogo_small.png"> <tr> <td> </td> </tr> </table>
Your html is wrong anyway as it possibly should be more like this.
<table border="0" cellpadding="0" cellspacing="0" align="center" width="960">
<td style="height: 210px; background-image: url('/templates/icy_phoenix/images/dark/sitelogo_small.png') no-repeat;">
</td>
</table>
You possibly need to spend some time learning more about html, css and the structure of the .tpl files - Because once one starts to modify themes - one is generally left to their own devices for obvious reasons to complete what they are trying to do.
My advice is freely given on the assumption that you will ignore any part or all of it!
My Hobby
mort - View user's profileSend private messageVisit poster's website
