Post Swedish Translation For 1.2.24.51 RC2
The Swedish translation for 1.2.24.51 RC2 is finish.(all files)
OK, here is the file and if there are some swedish (or other) that download this and turn it to there site, please tell me if you find some missing translations.
http://code.assembla.com/icyphoenix_langs/subversion/nodes/trunk
Jogge
Edited by Mighty Gorgon, Sat 23 May, 2009 12:18: SVN link added
Jogge - View user's profileSend private messageVisit poster's website
Thanks for the useful Topic Jogge:
Mighty Gorgon (23 May)
Post Re: Swedish Translation For 1.2.24.51 RC2
Wow!
That's a great news.
Thanks, I will add it to SVN.
P.S.: can you please also translate lang_install.php? Thanks
Wow!
No problem MG, i load up it here when i am finish
Post Swedish Lang_install File
Hera are the Swedish lang_install.php file
Jogge
lang_install.zip
Filename: lang_install.zip
Filesize: 6.35 KB
Downloaded: 43 Time(s)
Post Re: Swedish Lang_install File
Jogge,
I'm going to merge this topic with your other translation topic.  This way your translations for RC2 are in the same place.
Thanks for getting this ready so quick!
Chaotic - View user's profileSend private messageVisit poster's websiteView user's personal gallery
SVN updated...
You can use either a client or this link:
Thanks!
Thanks for your work Jogge
Great JOB
