lord1
 Translating IP Into Romanian.
Hi i need some help translating ip.
Do i need to translate all the lang_ files or just lang_main.php ?
Please list me the files that need to be translated.
Edit.
I will update the progress here.
Progress:40%
#1 Fri 13 Aug, 2010 09:32 |
buldo
 Re: Translating IP Into Romanian.
Do i need to translate all the lang_ files...
The first one, you have to translate all language variables in all language files.
____________ ~~~ Andrea ~~~
User #379756 on Linux Counter
#2 Fri 13 Aug, 2010 09:46 |
lord1
damn... heh back to work then,I will post here when im done.
I think it will finish it in 2 days or less.
#3 Fri 13 Aug, 2010 11:05 |
buldo
I think it will finish it in days or less.
Don't worry, take your time.
#4 Fri 13 Aug, 2010 11:19 |
lord1
ok, i want to test lang_main.php but
Change Lang
By enabling this option a link to each available language will be created on forum index, for quick language switching.
well its not working neither in dynamic block menu.
what can i do , i didnt cheked templates/default/nav_quick_link.tpl maybe this could be the problem?
#5 Fri 13 Aug, 2010 11:50 |
buldo
You don't have to check/modify anything for using your new language, you can simply use another language that exist replacing all lang file with yours or just create a new language directory called "lang_romanian".
#6 Mon 16 Aug, 2010 14:25 |
lord1
i did that already,but i dint made my self clear ,sorry what i ment to do was to allow users,adms etc to change language, not only guests.
#7 Mon 16 Aug, 2010 14:28 |
buldo
i did that already,but i dint made my clear sorry what i ment to do was to allow users,adms etc to change language, not only guests.
They can change language in their profiles, otherwise, a quick solution maybe to create some links to change language using the dynamic menu:
http://www.yousite.ext/index.php?l=english
http://www.yousite.ext/index.php?l=romanian
http://www.yousite.ext/index.php?l=italian
http://www.yousite.ext/index.php?l=spanish
#8 Mon 16 Aug, 2010 14:41 |
lord1
im back translating ip into romanian but i have found a small problem
in our language these are caled (diacritice) diacritics and i saw ip cant show them.
Ă ă
 â Î î.
Ș ș Ț ț
is there any way to change the overall encoding of the site?
| Description: |
| Filesize: |
31.54 KB |
| Viewed: |
41 Time(s) |
#10 Thu 28 Oct, 2010 18:59 |
Limun
Location: ![[Censor] (Croatia) croatia.png](images/flags/croatia.png) [Censor]
Ă ă
 â Î î.
Ș ș Ț ț
did you traied Special Characters ?
http://webdesign.about.com/od/localization/l/blhtmlcodes-ro.htm
so example :
if you want to write "Lo Ţ"
you need put like this " Lo & # 3 5 4 ; " of course without spaces betwen & # 3 5 4 ;
#11 Thu 28 Oct, 2010 19:57 |
lord1
V? rug?m s? introduce?i numele de utilizator ?i parola pentru a Mergeti,
yes,but not all of them are writen like that some are like this 1 above.
the diacritics are shown like a "?" . and a see the lang_main.php has the same prob fsss
I think it was writen with the wrong encoding on.. damn
#12 Thu 28 Oct, 2010 20:43 |
Limun
it work on my forum
try this in lang_main
#13 Thu 28 Oct, 2010 21:00 |
lord1
you ve just copied the code i posted and worked?
V? rug?m s? introduce?i numele de utilizator ?i parola pentru a intra
#14 Sat 30 Oct, 2010 20:11 |
Limun
no...i copied code from my second picture into lang_main.php
this one
#15 Sat 30 Oct, 2010 20:18 |
| Link this topic |
| URL |
| BBCode |
| HTML |
