Post [Theme Release 1.3] Agent Themes
Here are some great dark themes 5 in one... great for gaming sites etc
Main index Page
 agent_themes
Please Download Here
My last themes for a bit..
Enjoy
Thanks for the useful Topic DWho:
KugeLSichA (28 July), Mighty Gorgon (02 August), TopoMotoV3X (31 May), Costa (21 April)
Post Re: [Theme Release 1.3] Agent Themes
These look really brilliant DWho.
I love these dark themes.
great job mate
Icy-Mods.com ( IP 2.0 RC-1)
spydie wrote: [View Post]
great job mate
Thank you
Check your DL please.
your site says the themes do not longer exist
 dibujo_1248474091_659674
Thanks... I was uploading to it and then it must have cut me off...
trying to sort it out.... my interment keeps cutting out
OK
i´ll try again tomorow.
It´s time to go to bed
OK
All working now thanks for letting me know...
Recheck the link please.
Still same message
The file you want to Download does not exist
Still same message
Sorry I deleted that link and uploaded a fresh file try the link now in first post
fixed
its working
Thx DWho
Edit
did you fix that in your site aswell ???
cause if i go to templates and styles download happend the same
EDIT
there to change calendar colors??
If you got minicalendar enabled it looks horrible and nearly unreadable
see here
 dibujo_1248512721_586782
fixed
its working
Thx DWho
Edit
EDIT
see here
Thanks for pointing out the calendar I missed that... just uploading the themes now and with the footer fix give it 15 mins
Hi, Love the theme however I was wondering 2 things.
A: Is it possible to change the height of the main header for the template "I have done it in others however I don’t appear to be able to find what I am looking for.
B: Is it possible to replace the default header logo with a FLASH logo. "If so, any suggestions on what code to change and to what"?
Please note: I attempted to implement a flash header code referenced in this thread Add flash header in place of default however had no luck getting it to work. The default small_logo.png graphic still shows and there is no place holder for the "flash code" I had inserted.
Wasn’t it supposed to be possible to use flash in the headers with this new version of IP?
Thx in advance for the feedback.
Turbotech - View user's profileSend private message
Turbotech wrote: [View Post]
To A: its possible, but this includes changing sizes of al images componing the header.
To B :
OPEN templates/agent/overall_header.tpl
<td align="center" height="100%" valign="middle" >
        <!-- IF GL_BLOCK -->
        <!-- BEGIN ghleft_blocks_row -->{ghleft_blocks_row.OUTPUT}<!-- END ghleft_blocks_row -->
        <!-- ELSE -->
        <div id="logo-img"><a href="{FULL_SITE_PATH}{U_PORTAL}" title="{L_HOME}"><img src="{FULL_SITE_PATH}{SITELOGO}" alt="{L_HOME}" title="{L_HOME}" /></a></div>
        <!-- ENDIF -->
        </td>
        <td align="center" valign="middle"><!-- IF S_HEADER_BANNER --><center><br />{HEADER_BANNER_CODE}</center><!-- ELSE -->&nbsp;<!-- ENDIF --></td>
        <td align="right" valign="middle">
        <!-- <div class="sitedes"><h1>{SITENAME}</h1><h2>{SITE_DESCRIPTION}</h2></div> -->
        <!-- IF GR_BLOCK -->
        <!-- BEGIN ghright_blocks_row -->{ghright_blocks_row.OUTPUT}<!-- END ghright_blocks_row -->
        <!-- ELSE -->
        <!-- IF S_LOGGED_IN -->&nbsp;<!-- ELSE -->&nbsp;<!-- ENDIF -->
        <!-- ENDIF -->
        </td>
        <!-- ELSE -->
        <div id="logo-img"><center>
          <a href="{FULL_SITE_PATH}{U_PORTAL}"><object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,0,0"
width="800" height="150" id="text" align="top">
<param name=movie value="http://www.your_site/banners/mods.swf"><param name=quality value=high><param name=wmode value=transparent>
<embed src="http://your_site/banners/mods.swf" quality=high wmode=transparent width="800" height="150" name="text" align="top"
type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer">
</embed></object>  </a>
        <!-- ENDIF -->
        </td>
        <!-- ELSE -->
        <!-- ENDIF -->
        </td>
create an folder in your root like banners/ where you put your swf file
previously you should have sorted the header height problem
look for top-logo and all images asociated to the header
BRAVO!
Thanks again for the feedback sir , It worked perfectly!
Thanks Spydie....
I am finally back online so will be a lot more active from now on...
Glad you like the theme..
