SOLVED I Need Help To Edit The Welcome
Subject: SOLVED I Need Help To Edit The Welcome
My english is not very good but I try :oops:
I need to know where can I edit the welcome block is locate in the center, thanks a lot.
--->>Welcome to Icy Phoenix<---
Subject: Re: I Need Help To Edit The Welcome
OPEN language/YOUR LANGUAGE/blocks/lang_welcome_block.php
$lang['Welcome_Message'] = 'Welcome to <span class="topic_glo">Icy Phoenix</span><br />';
$lang['Welcome_Message'] = 'Everything else!';
I hope that this is usefull to all members alround this board!
Thanks a lot for help me but I do it, I edit the file lang_welcome_block.php (english and spanish) but nothing happen, everything still there :| I refresh my web several times to see if have changes but nothing
empty cache
Can you tell me how can I clean the cache or empty like you say? sorry but I don't know a lot about this
if you are using firefox go to Tools > Options > Privacy > Empty Now > Select Cache and then OK. Chace Emptied
if you are using Internet Explorer go to Tools > Internet Options > General > Exploration Cronology > Delete or a similar path ;)
Thanks again, I found it and clear the cache but I don't see any changes in my web, the same thing,
I was editing this files and I don't know where are the wrong :|
language/lang_english/blocks/lang_welcome_block.php
language/lang_spanish/blocks/lang_welcome_block.php
$lang['Title_welcome'] = 'Bienvenido';
$lang['Welcome_Message'] = 'Bienvenido a Ayy Que Rico';
it's right :shock:
It's right but it don't work, still the same original text, don't see any changes :|
Try to clear cache with ftp. I mean please empty your cach folder on your host ;-)
EDIT: If you search this site, you can find this ;-)
SOLVED
Thanks to everybody :D
Generation Time: 0.4984s (PHP: 4% SQL: 96%)
