Quick Reply, Characters And Image Links
Subject: Quick Reply, Characters And Image Links
Hi :D
Ok, here I go:
  • How can I show Quick Reply "open" by Default?
  • How to remove the "restriction" when I have some characters on nicks like ä
  • How to remove the image linking, I want the images in posts and signatures but no with the "link" part (open image in new window).
Thanks and regards to all :mry:
:mrgreen:
Subject: Re: Quick Reply, Characters And...
  1. Open templates/ca_aphrodite/xs/xs_toppic.tpl
    <div id="quick_reply" style="display: none; position: relative; ">
    <div id="quick_reply" style="position: relative;">
    It should work.
  2. Open includes/usercp_register.php
    if ( !preg_match("/^[a-z0-9&-_ ]+$/i", $username) )
    ADD YOUR CHARS IN THE REGULAR EXPRESSION FOLLOWING THE REGULAR EXPRESSIONS RULES
    if ( !preg_match("/^[a-z0-9&-_%£ ]+$/i", $username) )
    Remember that you should not allow other chars, because you may be exposed to security issue... do it at your own risk.
  3. Open includes/bbcode.php
    $html = '<a href="' . $params['src'] . '" target="_blank" title="' . $lang['OpenNewWindow'] . '">' . $html . '</a>';
    $html = $html;
Your support credit is now over for about a week... :LOL:
Subject: Re: Quick Reply, Characters And Image Links
with the new bbcode.php (included con patch .14) the modification of the image link it's the same?
it didn't work for me :roll:
Zuker wrote: [View Post]
Yes, it should work in the same way... try to empty the cache and disable precompiled posts to check. :roll:
Generation Time: 0.4359s (PHP: 7% SQL: 93%)
