Update To IP Final Release...
Subject: Update To IP Final Release...
ALTER TABLE `ip_cms_blocks` DROP `cache`
+++ Error: Can't DROP 'cache'; check that column/key exists
ALTER TABLE `ip_cms_blocks` DROP `cache_time`
+++ Error: Can't DROP 'cache_time'; check that column/key exists
DELETE FROM `ip_cms_config` WHERE `config_name` = 'portal_header'
+++ Successfull
DELETE FROM `ip_cms_config` WHERE `config_name` = 'portal_tail'
+++ Successfull
DELETE FROM `ip_cms_config` WHERE `config_name` = 'cache_enabled'
+++ Successfull
DELETE FROM `ip_cms_config` WHERE `config_name` = 'md_cache_file_locking'
+++ Successfull
DELETE FROM `ip_cms_config` WHERE `config_name` = 'md_cache_write_control'
+++ Successfull
DELETE FROM `ip_cms_config` WHERE `config_name` = 'md_cache_read_control'
+++ Successfull
DELETE FROM `ip_cms_config` WHERE `config_name` = 'md_cache_read_type'
+++ Successfull
DELETE FROM `ip_cms_config` WHERE `config_name` = 'md_cache_filename_protect'
+++ Successfull
DELETE FROM `ip_cms_config` WHERE `config_name` = 'md_cache_serialize'
+++ Successfull
DELETE FROM `ip_cms_block_variable` WHERE `config_name` = 'portal_header'
+++ Successfull
DELETE FROM `ip_cms_block_variable` WHERE `config_name` = 'portal_tail'
+++ Successfull
DELETE FROM `ip_cms_block_variable` WHERE `config_name` = 'cache_enabled'
+++ Successfull
DELETE FROM `ip_cms_block_variable` WHERE `config_name` = 'md_cache_file_locking'
+++ Successfull
DELETE FROM `ip_cms_block_variable` WHERE `config_name` = 'md_cache_write_control'
+++ Successfull
DELETE FROM `ip_cms_block_variable` WHERE `config_name` = 'md_cache_read_control'
+++ Successfull
DELETE FROM `ip_cms_block_variable` WHERE `config_name` = 'md_cache_read_type'
+++ Successfull
DELETE FROM `ip_cms_block_variable` WHERE `config_name` = 'md_cache_filename_protect'
+++ Successfull
DELETE FROM `ip_cms_block_variable` WHERE `config_name` = 'md_cache_serialize'
+++ Successfull
UPDATE ip_album_config SET config_value = '.0.56' WHERE config_name = 'album_version'
+++ Successfull
INSERT INTO ip_config (config_name, config_value) VALUES ('digests_php_cron_lock', '0')
+++ Error: Duplicate entry 'digests_php_cron_lock' for key 1
INSERT INTO ip_config (config_name, config_value) VALUES ('allow_only_id2_admin', '0')
+++ Error: Duplicate entry 'allow_only_id2_admin' for key 1
INSERT INTO ip_config VALUES ('ip_version', '1.1.0.15')
+++ Error: Duplicate entry 'ip_version' for key 1
UPDATE ip_config SET config_value = '1.1.0.15' WHERE config_name = 'ip_version'
+++ Successfull
UPDATE ip_config SET config_value = '.0.22' WHERE `config_name` = 'version'
+++ Successfull
UPDATE ip_album_config SET config_value = '1.4.2' WHERE config_name = 'fap_version'
+++ Successfull
UPDATE ip_config SET `config_value` = '3.0.7' WHERE `config_name` = 'upi2db_version'
+++ Successfull
CHMOD Files
CHMOD 0777: cache
+++ Error CHMOD 0777: cache
CHMOD 0777: ctracker/logfiles/logfile_attempt_counter.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_attempt_counter.txt
CHMOD 0777: ctracker/logfiles/logfile_blocklist.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_blocklist.txt
CHMOD 0777: ctracker/logfiles/logfile_debug_mode.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_debug_mode.txt
CHMOD 0777: ctracker/logfiles/logfile_malformed_logins.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_malformed_logins.txt
CHMOD 0777: ctracker/logfiles/logfile_spammer.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_spammer.txt
CHMOD 0777: ctracker/logfiles/logfile_worms.txt
+++ Error CHMOD 0777: ctracker/logfiles/logfile_worms.txt
CHMOD 0777: files
+++ Error CHMOD 0777: files
CHMOD 0777: files/album
+++ Error CHMOD 0777: files/album
CHMOD 0777: files/album/cache
+++ Error CHMOD 0777: files/album/cache
CHMOD 0777: files/album/med_cache
+++ Error CHMOD 0777: files/album/med_cache
CHMOD 0777: files/album/wm_cache
+++ Error CHMOD 0777: files/album/wm_cache
CHMOD 0777: files/posted_images
+++ Error CHMOD 0777: files/posted_images
CHMOD 0777: files/thumbs
+++ Error CHMOD 0777: files/thumbs
CHMOD 0777: images/avatars
+++ Error CHMOD 0777: images/avatars
CHMOD 0777: logs
+++ Error CHMOD 0777: logs
CHMOD 0777: pafiledb/uploads
+++ Error CHMOD 0777: pafiledb/uploads
CHMOD 0777: pafiledb/cache
+++ Error CHMOD 0777: pafiledb/cache
CHMOD 0777: pafiledb/cache/templates
+++ Error CHMOD 0777: pafiledb/cache/templates
CHMOD 0777: pafiledb/cache/templates/ca_aphrodite
+++ Error CHMOD 0777: pafiledb/cache/templates/ca_aphrodite
CHMOD 0777: pafiledb/cache/templates/mg_themes
+++ Error CHMOD 0777: pafiledb/cache/templates/mg_themes
CHMOD 0666: includes/def_themes.php
+++ Error CHMOD 0666: includes/def_themes.php
CHMOD 0666: includes/def_tree.php
+++ Error CHMOD 0666: includes/def_tree.php
CHMOD 0666: includes/def_words.php
+++ Error CHMOD 0666: includes/def_words.php
CHMOD 0666: language/lang_english/lang_extend.php
+++ Error CHMOD 0666: language/lang_english/lang_extend.php
after I lanuched update_to_ip.php this is the page... I have 1.0.14.14 and I choose the fourth option of upgrade...
what's happen?
Subject: Re: Update To IP Final Release...
U only have to chmod files now and enjoy icy phoenix ;)
feelbeen wrote: [View Post]
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
+++ Successfull
CHMOD Files
CHMOD 0777: cache
CHMOD 0777: files
CHMOD 0777: logs
what's happen?
Click fresh installation in the details and apply all the CHMODs in the list
No mate... he is upgrading
No need to do fresh install
Zuker wrote: [View Post]
The 14th (or aroud that step) is appply all CHMODs from fresh install.
When i upgrade my ip the files are chmoded and no need to do that...
If files aren't chmoded when upgrading they won't be chmoded when runing fresh install i think (despite that when running fresh install u will loose data)
I don't understand anything...
1. Can't DROP 'cache'; check that column/key exists .... what does it mean?
2. the files in the list I wrote in the first post are already chmodded... I mean: I checked for example files/album (and also others) and the folder is chmodded 777... like it says in the list...
I am thinking that the sql file "cache" holds data that your previous install had. It needs to be there....
The same thing happened to me. I found everything to work good. One thing I always notice;
If you use a program to FTP, sometimes depending on the .htacess file, you can only change CHMOD from your site FTP...
hope this helps. My site is running fine.
After reading your post, I am going to double check my CHMODS to make sure they are correct from the site FTP.
check my site: http://www.portal.thegtsaga.net/main/index.php
gearhead wrote: [View Post]
I don't understand your help... I check my chmods by FTP...
what I have to do to have a right upgrade?
A little issue i don't understand
what is the problem about your upgrade? is it your site running?
Yes it is running but now I locked it for the upgrade...
OK... This is what I'm tring to do: Upgrade From Icy Phoenix 1.0.14.14 RC
When I arrive to the 8th step this is the message:
Remember that this file have to be in your root!
Upgrading options:
Update to latest Icy Phoenix from phpBB or any older phpBB XS version
Update to latest Icy Phoenix from phpBB XS 058
Update to latest Icy Phoenix from Icy Phoenix 1.0.5.5 beta
Update to latest Icy Phoenix from Icy Phoenix 1.0.11.11 RC (or higher)
and I choose the 4th option: Update to latest Icy Phoenix from Icy Phoenix 1.0.11.11 RC (or higher) 'cause I have IP 1.0.14.14;
then the list of errors... the fist two of which I don't know the meaning, and the files not chmodded but that are already chmodded...
:roll:
Some errors are because some db changes are listed to have a safe upgrade. I'd also errors, but are because that field on my db is also there.
If files are chmoded, don't worry and enjoy icy phoenix ;)
this is want I'd like and I'm going to do...
ok... thank you...
I hope all will be good...
8)
i hope to
:mricy:
I am sorry. I had the same errors too.
Ok, My site ran fine for 2 days, then it crashed.
I think when I upgraded, I didn't fix the problems, so they got worse. I am now doing fresh install.
:( :roll: :idea: :)
Generation Time: 0.2838s (PHP: 8% SQL: 92%)
