Blank Pages After Upgrading Or Only Header? Try This...
Subject: Blank Pages After Upgrading Or Only Header? Try This...
Hile, neighbours and friends...
Here's what I did:
1st made a backup of the files
2nd I uploaded the update php file and run it as admin... No problems
3rd I erased all files from previous release (except config.php, album_mod/upload/*.* files/*.* includes/*.* and templates/*.*)
4d Uploaded the whole new version and all patches
5.- I restored def_*.php from the backup I made
6.- I applied the correct permissions to every folder
After that:
1.- I can't see almost any post in normal mode, but no problem in lo-fi mode.
2.- I can't upload any picture either in normal or lo-fi mode
3.- I can't use the 3column.tpl layout (I had to re-configurate the 2column layout)
So
1.- I restored my backed up copy and same problems were still there.
I also:
1.- Created a brand new installation of XS2 in a new folder and in a new DB
2.- Everything worked right.
3.- I changed de config.php of the new XS2 installation to use the old folder and changed the folder in the ACP for the old DB
4.- The problems I told before came again in the brand new installation
so I figured out it was problem of the DB and not the files, so:
1.- I went to de Admin panel of my domain and repaired the old database
2.- I marked every table of my DB in phpMyAdmin and fixed and repaired them.
No changes... Errors still persist...
And I tried one more thing...
I uploaded the quick_xs_settings.php that MG posted in another message and tried all the three configs and the same problems are still there...
Anyone has any idea on what else could I do???
Thnx in advance!!
Subject: Re: Problems After Upgrading To 058
maybe they are corrupted
Subject: Respuesta: Problems After Upgrading To 058
Just because in the upgrade instructions MG says
(...)Upload all new files (except config.php, install/*.*, contrib/*.* and includes/def_*.php(...)
So, instead of avoiding upload includes def_*.* I prefered to upload the original ones and then replace them with the backed-up ones, as its faster to do this way...
Anyway there is no difference in leaving the old ones or the new ones, the same problems are still there!!
Any other suggestion?
Thanks for your interest, difus!
If MG said it is OK
after changes are made remember to clear cache folder always
can we take look at your site
it is www.ka-tet-corp.com/portal2.0/index.php ?
if you can post one test post
Thnx again!!
If anyone needs it there is always a test account: user:tester pass:test
Yes, I cleared the cache in two ways: Through the ACP (Manage Cache --> Delete chache) And through my ftp, deleting the contents of the cache folder... Nothing happened :(
For instances:
A normal post:
--> http://www.ka-tet-corp.com/portal2....?p=35810&lofi=0 (only overall_header.tpl is parsed)
The same post in lofi mode:
--> http://www.ka-tet-corp.com/portal2....?p=35810&lofi=1
I have reviewed the errors.log of my site and I have multiple instances like this one:
PHP Fatal error: Allowed memory size of 8388608 bytes exhausted (tried to allocate 737280 bytes) in /home/ka-tet-corp.com/data/htdocs/portal2.0/cache/tpl_ca_aphrodite.viewtopic_body.php on line 664
Maybe it has something to do with?
Now... This I don't really understand... :( Some posts works, some others doesn't!!!!
I can always see this one: http://www.ka-tet-corp.com/portal2....?p=35811&lofi=0
But I can never see this one: http://www.ka-tet-corp.com/portal2....?p=35255&lofi=0
And every time I try to see this one: http://www.ka-tet-corp.com/portal2.0/viewtopic.php?p=35362#35362 my computer tries to download viewtopic.php
And what's most amazing: Half an hour ago I couldn't see this one: http://www.ka-tet-corp.com/portal2....?p=35810&lofi=0 but now I can :shock:
Can't see the differences between them!!!
I can see these posts :shock:
you are quick :mrgreen:
You can see pages where the topics were posted today
grrrrr!!!!!
I see... I can see posts that were replyed yesterday and today... But only as guest :( I can't with my admin account :(
Try to see this one: http://www.ka-tet-corp.com/portal2....?p=35255&lofi=0
difus wrote: [View Post]
:D :D That's because I have nothing to do right now... Except worring about my web :mrgreen: :mrblue: :mrorange: :mrviolet: And I have a whole loooooong weekend to worry about!!! :(
try to synchronize forums
Well, actually I tried that several times... There are two ways:
ACP/Admin Forums/Administrate
and
ACP/Admin Forums/Admin sync
Or something like that... As I use the spanish version I'm not sure about the correct links...
I will try them again and will say something!!!
Thnx very much for your interest!!
--Edited--
Nothing happened :(
I think something wrong with your database
Did the search here I remember that somwhere the same problem was solved
I agree!!!
But unfortunatelly I've tried to restore a backup of the DB but the server does nothing... I've talked to the hosting and they say that most of them are on hollydays and will try to do something with that issue next week :(
Trying to restore from the ACP I get an execution time error...
Thank you very much, difus!!!
yes it is php.ini configuration on server
Generation Time: 0.2452s (PHP: 8% SQL: 92%)
