SOLVED URL Rewrite Enable / Disabled And Now Can't Access Forum Post
Subject: URL Rewrite Enable / Disabled And Now Can't Access Forum Post
I was testing the URL Rewrite function and I enabled it on my site. I then checked to see if it worked and it did not appear to have so I went back and changed the URL Rewrite
option to disable.
Now I can not go to any of my post in my forum.
I can see the main forum page with all of my categories listed but when I try and go into one of my categories it gives the following error:
Before going on... please make sure you have read and understood this post. It contains important informations regarding this site.
Click Here to read it
and when I click on the read it says
The topic or post you requested does not exist
I am not sure what I need to do and have searched every Mod Rewrite post i can and haven';t found the answer.
Any help would be greatly appreciated.
I have tried clearing all of the cache with no luck.
I have done all of the DB maintenance options with no luck.
Subject: Re: URL Rewrite Enable / Disabled And Now Can't Access Forum Post
Strange.
Are you sure you don't have FTR enabled?
Go to ACP -> General -> FTR -> Deactivate this mod? -> YES
Chaotic wrote: [View Post]
Strange.
Awesome, that was it.
Thanks for the quick reply
Inactive User
Subject: Re: SOLVED - URL Rewrite Enable / Disabled And Now Can't Access Forum Post
Has this been reported as a bug - because FTR should recognise the change to and from friendly url's also? ;)
Generation Time: 0.5728s (PHP: 3% SQL: 97%)
