[quote]../pafiledb/cache/templates/mg_themes Error This File/Folder exists but its permissions may not be modified automatically, please apply CHMOD manually and then click on "Start Install Anyway".[quote]
I downloaded the Icy Phoenix release twice, and I couldn't find mg_themes.
Should I continue on, or does someone have a download of it that I can use?
Missing File
Subject: Re: Missing File
Hello, for this you must set the CHMOD permissions with your FTP program, i used FILEZILLA for this, this app can
change the permissions for you, if you want.
In the ip_root folder is an docs folder. so before you upload the files in ip_root, check out the readme_english.html in docs folder. There are instructions which folders and underfolders/files needs which CHMOD permissions.
Greetz
Liquid 1520 wrote: [View Post]
Greetz
Look in the ip_root folder for this:
ip_root/pafiledb/cache/mg_themes and CHMOD 777 it.
Here are the rest of the folder/files you need to CHMOD. Like stunnah said, it's in the DOCS folder in your download.
Generation Time: 0.491s (PHP: 3% SQL: 97%)
