Icy Phoenix .COM Is Going To Be Moved
Subject: Icy Phoenix .COM Is Going To Be Moved
Hi guys,
I would just to let you know that this site will remain closed for at least a couple of days, because I'm moving it to a new server.
After many months of bad performances and also some JS and PHP injections I have decided to shut the current hosting service and buy a dedicated server.
This new solution is costing a lot more... but I hope to definitely solve all performances issues and bad server configuration.
I will try to release a new beta before moving, so you can play with it while this site is closed.
Unfortunately I really need to close the site because I not only need to move files and db, but also I need to switch registrar, and this will cause a service blackout for a small (I hope) amount of time.
I will try to have all things sorted out before this weekend.
Stay tuned.
Subject: Re: Icy Phoenix .COM Is Going To Be Moved
when are you going to start with your task Luca?
I have just started... :P
The problem is that I don't know how long it will last. :mricy:
:mricy: Yes, that would be great.
Good luck for moving this site :!:
Ok boss.
That the move goes well.
Greets.
Good look...
We are here to help you.... :LOL:
just kidding :mryellow:
thank you for info
I await you have no problems during the moving...
Can you post the IP adress of the new server to add it to the hosts file in order we can get into the page while the DNS gets refrshed on the ISP DNS storage servers?
No... I prefer to keep the whole site closed to avoid any kind of issue with DNS and DB. :mricy:
As you wish.
BTW, I was refering to our own computer IP adresses pool, not anything related to your server
Inactive User
Aww! And I thought it was something else - :LOL: :mrgreen:
Yep! Servers can be a pain, and I feel sorry for those here who have a lousy IP, and wonder why they have so many problems. :shock:
Buon lavoro Luca! ;)
This sounds like it's going to be a ton of fun. :LOL:
Good luck!
Then good luck for moving, MG. :mrorange:
We`ll have fun with the beta and sort
the BUGS in alphabetical order.... :LOL: :twisted:
Only a joke.... 8)
Well... it took more than 2 days to change two numbers in their damn DB... but now it should be all over.
I'm restoring all the features of the site right now, please let me know if this site works correctly.
Generation Time: 0.6851s (PHP: 3% SQL: 97%)
