Icy Phoenix 1.2.20.47 Beta 2
Goto page 1, 2, 3  Next
Subject: Icy Phoenix 1.2.20.47 Beta 2
Hi all,
here is the beta 2 version of the development package.
What's New
  • CMS Administration recoded with new features (some AJAX) and restyled
  • CMS Blocks and Layouts recoded from scratch to increase flexibility and performance (now block style is in a single file to help designing new styles)
  • New template structure: it is now possible to create brand new templates by just creating a CSS and a CFG file, this will reduce the number of files needed for each template, reducing also the job in case of updates or customizations; not only, you will be able to easily create combinations between different templates without having to duplicate directory structure
  • Common CMS and ACP templates now fully independent from all other templates
  • Common JS and CSS in common folder and possibility to include extra CSS and JS via PHP without editing TPL
  • Some Functions and other common includes splitted among several files to reduce memory charge and increase performance
  • Created new overall vars and switches to increase flexibility and performances (old switches were based upon loops, new ones are based on conditions, which are faster to be processed)
  • English language files grammatically reviewed (thanks Lopalong!) and in some cases updated to the new phpBB 3 format
  • New Junior Admin permission which gives full admin power while in the forum but restricted in ACP and CMS (ACP modules can be assigned via Junior Admin management and CMS permission for CMS management)
  • Brand new Statistics system which integrates new features and replace also old Site History page
  • Bots Parsing now is DB dependent and bots can now have REG access... also you can now add a switch for bots in TPL files to avoid bots spidering something you don't want them to
  • URL Rewrite modified to be more efficient
  • Print Page improved
  • Added Google Search page to be used alternatively the standard search system, this will reduce the charge on your server
  • Colorize username function recoded to reduce looping and cache issues with a large userbase
  • Recoded caching system which in older Icy Phoenix version was proved to fail for high traffic sites: this new way to cache should be more efficient and should reduce CPU charge under stressing condition
  • Birthdays and Calendar should now use less resources than before, again big sites will benefit from this
  • New CRON system which should be easier to be customized and improved... basic functions already added, new features to come with future versions...
  • Created new user related functions to simplify Icy Phoenix integration and coding: user_get_avatar, build_im_link, PM Class, generate_user_info
  • AJAX Sorting in some ACP and CMS pages to speed up things in administrating things
  • New Recent function allowing admins to track latest users activity
  • Forums Sorting capabilities both by adding alphabetical sorts and columns headers links
  • Higher Lang Encoding compatibility
  • Mass PM feature integrated in Mass Email section
  • Brand new Ads and Banners system
  • Mass Email supports now full HTML format for nicely formatted newsletters
  • Smileys Categories section... it is hardcoded to improve performances even with thousands of smileys
  • Step by step DB Backup System similar to MySQLDumper... to avoid nasty timeouts when backing up the site
  • HighSlide JS (http://highslide.com/) integration
  • Many smaller updates and features... install the beta to discover all of them!
Support
Regarding the support for beta, I'll quote phpBB beta release statement:
Acyd Burn wrote:
During the beta phase a minimal level of support will be given. We will provide answers to general setup questions, configuration problems and support for determining common problems mostly related to bugs. We will not support modifications, custom code/style additions or any users using the beta packages within a live environment.
For some support questions or bug reports we may ask you to re-install the beta, clean tables in the database, purge data or other actions which are not advised to do in a live environment. So please be aware that you are still on your own if you run the beta in such an environment.
Beginning with the release candidates full support will be given.
Please note that if you decide to install this package or upgrade your existing site into live environments, you do it at your own risk... and you may not be able to recover your all datas in case something goes wrong. Do it only if you know really well what you are doing.
As usual, no code changes will be released, and won't probably be released for any version in the future. This is because the package is quite huge and writing code changes requires much time: as I already said in the past, I prefer to focus my free time on developing the package instead of writing huge code changes that could be difficult to be applied. Trust me, in most cases it is quicker to replace old files with new ones and reapply eventually added mods (you should take note of the mods you have applied). My efforts will be dedicated to the upgrade procedures to allow you to upgrade your sites with the smallest unexpected issues.
Anyway for final release, I'll try to provide a changed files package and a small template changes guide... or at least a list with the changed files for those who have modded their site or released templates. I'll try to give translators a list of changed files as well.
  • Requirements
  • Fresh Installation
  • How To Upgrade From Beta 1
Available Packages
This is only the standard package, should you be interested in having extra languages or styles, currently they are only available @ SVN (check the SVN topic to have more info about this):
http://svn.assembla.com/svn/icy_phoenix
http://svn.assembla.com/svn/icyphoenix_langs
Package Name: Icy Phoenix
Package Version: 1.2.20.47 Beta 2
Release Spot: It seems like you just realized that!!!
DOWNLOAD: Icy Phoenix 1.2.20.47 Beta 2
As per HighSlide JS license agreement I report this:
Enjoy Icy Phoenix!
Subject: Re: Icy Phoenix 1.2.20.47 Beta 2
Moving on up!
Great news -> going to test :mricy:
I have update from beta 1 in local, and in home appear this error:
Warning: Call-time pass-by-reference has been deprecated - argument passed by value; If you would like to pass it by reference, modify the declaration of [runtime function name](). If you would like to enable call-time pass-by-reference, you can set allow_call_time_pass_reference to true in your INI file. However, future versions may not support this any longer. in C:WMwwwportaleswsincludesalbum_modalbum_hierarchy_functions.php on line 774
and link to album don't go!
Switch to XAMPP...
Switch to XAMPP...
It seems you are using WM Server Tools which is very old and outdated... (if I'm not wrong it is still PHP 4 based).
Please try to upgrade to XAMPP and try again.
continued in italian support...
oooh, niceful news mr luca
lets go to try it :mryellow:
Parse error: parse error, unexpected ';' in album_comment_delete.php on line 228
appears when you want to delete a comment in the album (I adapted and replaced with the old version)
On the download page if the title of the file contains the characther ' " ' like in
' "Billy" '
in the header navigation links it comes out like this:
"Billy"
Your servers speed is quite slow, dunno, but I am not able to download the package.
I just downloaded it again and it took only 35 seconds.
Give it another try. 8)
tormentor wrote: [View Post]
' "Billy" '
"Billy"
Thanks, I should have fixed them on my working copy.
The ' " ' bug appears also in the album, you can see it here
http://www.icyphoenix.com/album_sho...sort_order=DESC
in the description if I use ' " ' it is written in the database in a wrong way...
Thanks I should have fixed this as well in my working package.
Page 1 of 3
Generation Time: 0.6827s (PHP: 4% SQL: 96%)
