hi guy´s and girl´s
got a little problem with my setup in mysql.
all the time i try to install IP on local i get an error message.
selected table does not suport full index names.
i´ve selected Utf8_general_ci
on my online server it run´s well with that but on local y get this using Wamp server.
SOLVED Anybody Got An Idea About Mysql-setup???
Subject: Re: Anybody Got An Idea About Mysql-setup???
For RC !!
open /install/schemas/mysql_schema.sql
find and delete
find and delete
sry, maybe i don´t explained well.
this happens on install. and stops the hole process
have a look here... should fix your problem
http://www.icyphoenix.com/viewtopic.php?f=4&t=3313&highlight=
:mrgreen: :mrgreen:
:mrgreen: :mrgreen:
Thx DWho, that solved my Problem.
I just wonder that that did´nt happen with Vista. Only with XP
Subject: Re: [SOLVED] Anybody Got An Idea About Mysql-setup???
got another prob now.
sh..t , after install i get an message that says
Can´t open /templates/mg_themes/mg_themes.cfg : this file does´nt even exist in my IP. not in .27 nor in RC2
error on line 1027 file functions.php
grumble. And my server startet to through errors around again. grrrr
windows encountert an error . apache server closed down
Found the Problem:
If anybody might stumble across this.
Some Spyware programms delete files on your computer.
It happend to me on my Icy Folders.
The style config files have been deleted by SuperAntiSpyWare Software.
Solution:
ReDownload the Files from IcyPhoenix.com and desInstall This Spyware programm.
spydie wrote: [View Post]
Found the Problem:
Solution:
Generation Time: 0.3028s (PHP: 11% SQL: 89%)
