SOLVED FAP SUPPORT - Template->make_filename(): Error - Template File Not Foun
Subject: FAP SUPPORT - Template->make_filename(): Error - Template File Not Foun
in ACP i have this error:
Template->make_filename(): Error - template file not found: ADM_TPLalbum_cat_select_body.tpl
i use ca_aphrodite, is this the problem? ok, but i don't understand what i have to change...
thanks :roll:
Subject: Re: Template->make_filename(): Error - Template File Not
Looks like you need to reupload album_cat_select_body.tpl to your yoursite.com/yourforum/templates/yourtemplate/admin/album_cat_select_body.tpl
Or did you recently do any changes to the file?(album_cat_select_body.tpl )
EDIT: Well also, what version of phpBBXS are you using?
Frost wrote: [View Post]
those files exist. I haven't done any change, i have just installed it.
the problem is for all album links in ACP:
Template->make_filename(): Error - template file not found: ADM_TPLalbum_config_body_extended.tpl
Template->make_filename(): Error - template file not found: ADM_TPLalbum_cat_body.tpl
Template->make_filename(): Error - template file not found: ADM_TPLalbum_personal_body.tpl
:roll:
I use phpBB XS 2 2.0.2.2
Hmm, try this...
Open:
album_mod/album_constants.php
Find:
$acp_prefix = (defined('IS_PHPBBXS')) ? ADM_TPL : 'admin/';
Replace With:
$acp_prefix = (!defined('IS_PHPBBXS')) ? ADM_TPL : 'admin/';
fantastic! now it works! thanks! you're great :mrorange:
you're welcome :lol_flag:
HI there., just reading the help you have given for a similar error code ... we have just installed a new theme from SubSilver to a Green theme.. and we've come up with this error...
Template->make_filename(): Error - template file not found: portal_page_header.tpl
unable to get back into My Admin ... is there another way thru the CPanel to change the details...
had a little bit of progess..... header had changed but still getting error: Template->make_filename(): Error - template file not found: layout/3_column.tpl
could someone please advise the best method to fix this... your help is greatly appreciated.... :mrviolet: :mrviolet: :mrviolet:
Subject: Re: SOLVED - Template->make_filename(): Error - Template
Reemplaze this files for original Icyphoenix ;) and restore all modificactions of the problem
OVRTAQ wrote: [View Post]
I'm thinking best way is to put portal_page_header.tpl in right place via ftp
Generation Time: 0.4619s (PHP: 4% SQL: 96%)
