Post How Disable Some Functions
hello, i want know, how delete or modify the image in link's bar...see in this example:
links
how disable visualization the GOOGLEBOT or YAHOO SLURP... for example:
bot
than....
how, i modify or delete some links in MAIN LINKS... for example:
men
Thanks!
eXtremeBitSend private messageVisit poster's website
Post Re: How Disable Some Functions
to edit the links, you have to go into ACP > Links > and then what do yo want to do
to delete the bot i don't know
to edit or delete quick links go to teplates/mg_themes/ and edit this file: nav_quick_links.tpl
sonoangeloSend private messageVisit poster's website
for bots
open index_body.tpl
and cut {BOT_LIST}
*VOLVO CLUB*
sonoangelo wrote: [View Post]
But you don't must delete thinks...
Take a look
Link
sure, you have not to delete the mg_switch
Of corse you know that    but maybe it could be helpful for other users
hi, i would know how edit or delete the banner in link box... for example, look the screen!
Filename: Immagine.JPG
Filesize: 75.6 KB
Downloaded: 671 Time(s)
eXtremeBit wrote: [View Post]
Why you don't use search function in this forum? All question on this topic are just made about 100 times! Anyway... can you see in the bottom of page the text "Modifica questa pagina"? I think that you can understand what means... enter on CMS and edit or delete all blocks of this page.
If you want to change logo you have to go in ACP->Links->Configurazione
