felix968
 FAP SUPPORT - Send Image From Album To Forum Post
hallo,
I'd like give an option for users (like photo4u) : send images from album to forum (phpbb) for comments.
I'm sure you can help me!
MK Portal 1.1.1
Phpbb forum 2.0.21
Photo Album Powered by: Mighty Gorgon Full Album Pack 1.4.0 © 2006
[based on Smartor Photo Album plus IdleVoid's Album CH & CLowN SP1]
#1 Thu 01 Mar, 2007 13:54 |
will_hough
 Re: Send Image From Album To Forum Post
If you are using FAP you should have a bit of BBCode underneath each of your images.
Copy/paste that code to display the thumbnail and a link to that image in your gallery.
#2 Thu 01 Mar, 2007 16:13 |
felix968
thank's will, but I do not understand: in which file have i insert that code?
#3 Thu 01 Mar, 2007 21:02 |
Artie
You enter that code as you enter your post text.
Below is pic id 76
#4 Thu 01 Mar, 2007 23:24 |
felix968
thanks Artie, this is a way.....but i'd like give a command directly in album mode to offer this option...so the member in his album mode can set an image and send it to a topic forum ....
#5 Fri 02 Mar, 2007 07:33 |
felix968
ok, let's try another way: in FAP we have personal galleries and various cstegories: but, now, you cannot send an image from personal gallery to a category, but chargin it from local pc to cathegory if you want too: is there a way to send image from persanal gallery to a public album cathegory?
#6 Sat 03 Mar, 2007 10:40 |
Artie
Admin can already do this, but for owner of personal gallery try this
OPEN album_modcp.php
FIND ( 2 INSTANCES OF)
$category_select .= album_get_simple_tree_option(ALBUM_ROOT_CATEGORY, ALBUM_AUTH_MODERATOR);
REPLACE WITH 2ND ONE WITH
//$category_select .= album_get_simple_tree_option(ALBUM_ROOT_CATEGORY, ALBUM_AUTH_MODERATOR);
$category_select .= album_get_simple_tree_option(ALBUM_ROOT_CATEGORY);
#7 Sun 04 Mar, 2007 00:14 |
felix968
Thanks Artie....it doesn't works, but I'm not sure about the change.
I post you new code in album_modcp.php, please tell me about:
else
$category_select .= '</select>';
// end write
#8 Sun 04 Mar, 2007 01:14 |
felix968
#9 Sun 04 Mar, 2007 01:18 |
Artie
:biggrin_03: You are welcome.
#10 Sun 04 Mar, 2007 02:17 |
lefty74
Cool idea, wondered about that myself a while ago but did not know where to look
thanks artie
#11 Sun 04 Mar, 2007 13:12 |
felix968
 ehem, artie, here I am with another question about: Can we select "move A COPY to" instead "move to".
Also now I have other personal galleries in the options "move to". So can we exclude the others personal galleries in the option?
Thanks again
#12 Sun 04 Mar, 2007 22:18 |
Artie
Yes I think Copy would be better suited here.
I will look into this when time allows me to.
#13 Mon 05 Mar, 2007 01:02 |
will_hough
I have users asking about this feature as well. Thank you for all your hard work Artie!
#14 Mon 05 Mar, 2007 03:59 |
felix968
big artie....remeber this one more!
#15 Thu 08 Mar, 2007 13:52 |
