Post Unable To Install Icy Phoenix 1.0.9.9 Beta
Hmmm I don`t understan this error.
I do CHMOD of Files & Folders Permission correctly,
I do  the second step  correctly too, bd name, bd user, all is good
next click in continue installation
and then said that:
Icy Phoenix Installation
Your config file is un-writeable at present. A copy of the config file will be downloaded to your computer when you click the button below. You should upload this file to the same directory as Icy Phoenix. Once this is done you should log in using the administrator name and password you provided on the previous form and visit the admin control center (a link will appear at the bottom of each screen once logged in) to check the general configuration. Thank you for choosing Icy Phoenix.
Since FTP extensions are enabled in this version of PHP you may also be given the option of first trying to automatically FTP the config file into place.
Choose Download Method
Attempt to FTP config file into place
Just send the file to me and I'll FTP it manually
Attempt to FTP config file into place                                 0
Just send the file to me and I'll FTP it manually               0
If I click in download with any option, it gives back again to the first step when CHMOD is necessary :S
but I'm sure that  I do CHMOD step  good
I don't know
In the past I install the xs mod perfect but ip it`s impossible for me now
The version of icy phoenix is this
 5.       Icy Phoenix 1.0.9.9 Beta (04 Mar 2007 05:48)
I want try this version before that RC release is ready
Thanks for all
something like that
step 1.
sshot1kw3
in this step I chmod all files
step 2.
sshot2pt5
here I fill all camps
step 3.
sshot3oo9
I choose the first o second option and then The page don't download nothing
and redirect me to
sshot1kw3
again
pd: in the same host I install a xs mod , and in the  third step I choose the second option and the download start.
and then up the config.php to ftp again and all right
here the xs http://www.xtremedd.com/xs_058b_lite/index.php
nothing else
diegomakSend private message
Post Re: Unable To Install Icy Phoenix 1.0.9.9 Beta
try to chmod these files manualy before the install.
*VOLVO CLUB*
yes, i do chmod manualy, I`m sure, and I verify after.
but no install.
I know how chmod files, in the xs I do it and its good.
   what will happen with this
hmmm at least the IP is Full install
another question,   can I update to Icy Phoenix RC  since this version Icy Phoenix 1.0.9.9 Beta????
or better install IP RC since 0???
HI, also for me the same error, but i try to install it in a windows host in public folder.
How I can resolve?
bye
Giucas
giucasSend private message
Hello ,
i have the Problem, too .
It's a linux server, php4, msql4 , i have checked the chmod before, but the same problem.  i make a config.php manually  and now,  it's running
I think its a general bug , because the problem is multipresent .
But then icyphoenix rocks and is a great boardsoftware -    thank you very much  @migthy
wallhallaSend private messageVisit poster's website
ThankYou wallhalla, but my config.php is totally blank. Can You put in a reply your  config.php(without the personal data)?
ThankYou again
Giucas
wallhalla wrote: [View Post]
Hello ,
Yes, no Problem. Here is a blank config.php example:
<?php
// phpBB 2.x auto-generated config file
// Do not change anything in this file!
$dbms = 'mysql';
$dbhost = 'localhost';
$dbname = 'YOUR DATABASE NAME';
$dbuser = 'YOUR DB-USERNAME';
$dbpasswd = 'YOUR DB_PASSWD';
$table_prefix = 'phpbb_';
define('PHPBB_INSTALLED', true);
Best regards, wallhalla
config.zip
Description: example
Filename: config.zip
Filesize: 334 Bytes
Downloaded: 384 Time(s)
Hi whallalla you are really the best!!
Thanx
<?php
$dbms = 'mysql';
