Post Questions On Beta Testing
Hello i have beta version Icy Phoenix 1.0.6.6 and i want to know will i be able to upgrade to latest version even though the latest version may not have upgrade instructions?
Or should i degrade to regular PHPBB then from there upgrade back to the latest version??
I really need the help before its too late
Most importantly though can i get insturctions on how to downgrade to regular phpBB?
Looking for webhosting?
Need a excellent host with 24/7 support and free installations for your scripts?
Then pick www.aonservers.com 24/7 in live-time support with tickets/aim/msn/live chat/phone support and more support features.
TheLastLegionSend private message
Post Re: Questions On Beta Testing
Wow, AON Hosting? I am a user there... anyways.
Backup forum database, and forum dictionary
You upload everything from IP 1.0.9.9 (or newest) into your forum dictionary.
EXCEPT config.php
do not delete the folders for now
Move install/update_to_ip.php
to forum_root/update_to_ip.php
delete install/ folder.
Run the "Upgrade from older Icy phoenix"
If you see "duplicate errors", you don't need to worry.
After finish correctly, delete update_to_ip.php
CHMOD config.php to 644 (if you can.. but we don't need it for upgrading).
Hope it works.
ShaythongSend private message
If you have 1.0.6.6 you can just replace the files (but not config.php and def_*.php ctracker/logfiles/*.*) and run the update script from your root.
How would i go about going to regular phpBB?
Hello someone?? plzzz help
Hello someone? I really need help with getting this to regular phpbb is there a guide to do this atleast please i have tons of visitors daily i need help plz hello
i don't understand your question
If i remember well there is such a script in install/contrib folder of icy phoenix.
Try to check and let me know.
MelSend private message
Yes: phpbb_clean_tables_1_0_8.zip
