Post [XS 0.58b] Who Is Main Admin?
I need to know who is considered the MAIN admin? The user with all protections, who can't be disabled and so on... id=1 ?
Post Re: [XS 0.58b] Who Is Main Admin?
The admin username selected when installing the forum.
CivUnited
tonyf12Send private messageVisit poster's website
So the users with ID=1 ...
and if I change a user's id with another one? The problem is: I am the first admin, I want another user to be the first admin and I want me to become a normal user. How can I do that?
I don't want to delete any user, just want to give my privileges to another one.
If I change the user ID I will have problems with posts and other things... or not?
userid=2 is main admin
but if you change id's you will got lot's of problems
because post are assigned to id's
Zuker wrote: [View Post]
Just as I thought...
I need to change the main admin (id=2) with a normal user... is there any way to do that?
Hi Vortex,
what do you think of changing only the name to Admin or Sitemaster.
And give the password to the new admin... how can change it
You must creat a new account and loose all you comments.
But you post them as admin... therefor its correct.
Could that be a way for you?
Maybe there is a way to change the post via myphpadmin from number 2 to XX
But that I don't know.
Thanks TheSteffen
TheSteffen wrote: [View Post]
Hi Vortex,
I'd like to apply a less invasive solution
I need user A to chang id with user B... but I want everything else to stay untouched: pms, posts, profiles and so on...
Uhm... I think it could be simpler: what do you think about manually modify the hardcoded protections to id=2 and changing it to another id?
Even if they are a lot, I don't mess around with the database, do I?
Would it not be enough just to change the user_level to 1 for a new Admin ?
ArtieSend private message
there are certain things that are set only to user_id = 2
Exactly... what do you think about changing the code directly?
Must be an XS & Icy thing
Artie wrote: [View Post]
mmm...
at phpbb, u cannot change user_id 2 nickname or edit their profiel if u are admin
mmm...
Sure you can.... I just did it
